Ballyhannon Posted September 29, 2013 Posted September 29, 2013 can anyone help please need haynes manual for my ep91 Starlet SR 1999
morgey Posted September 29, 2013 Posted September 29, 2013 they dont make them. depending what you plan on doing 97-99 ee111 corolla's have the same engine so you can use the manuals from them.
Ballyhannon Posted September 29, 2013 Author Posted September 29, 2013 Thanks morgey. I am trying to remove the airbag to fit an OMP steering wheel.
Glanza-Ben Posted September 29, 2013 Posted September 29, 2013 Just disconnect the battery then remove steering wheel plastics 4x Phillips screws, the behind wheel is 2 screws undo them and pull the air bag then disconnect the wiring and put the air bag some where safe then use a 19mm ratchet to remove the steering wheel then refit the new one with boss kit
Ballyhannon Posted September 29, 2013 Author Posted September 29, 2013 Thanks airbag out. This is a ep91SR. I have an OMP boss fits on the splins Ok but how you connect the horn?
Glanza-Ben Posted September 29, 2013 Posted September 29, 2013 Thanks airbag out. This is a ep91SR. I have an OMP boss fits on the splins Ok but how you connect the horn?I wired my own switch in for the horn
rob_bower Posted September 29, 2013 Posted September 29, 2013 You would either need to do this ^^^ of it is possible to get the connection from a none airbag toyota it's like a little brass connection on a spring which rides on the brass round on the back of the boss.
Ballyhannon Posted September 29, 2013 Author Posted September 29, 2013 Thanks this is proving more difficult that I had thought.
Ballyhannon Posted September 29, 2013 Author Posted September 29, 2013 Rob should have asked any ideas where to source this part?
Nanglebadger Posted September 30, 2013 Posted September 30, 2013 i had to wire in a new switch for mine, as getting one of the direct fit bosses is ~£100 or there abouts IIRC. few quid for a bush button off Demon Tweeks and job done. Phil.
Matt1878 Posted September 30, 2013 Posted September 30, 2013 No one needs a horn ... Unless your MOT tester is a tool and wont pass it
Glanza-Ben Posted September 30, 2013 Posted September 30, 2013 No one needs a horn ... Unless your MOT tester is a tool and wont pass it Happened to me lol went for a bent mot with no horn and other things and ended up having a proper mot and a fail haha
Nanglebadger Posted September 30, 2013 Posted September 30, 2013 he's from NI so yeah, he needs a horn for MOT. Phil.
Matt1878 Posted September 30, 2013 Posted September 30, 2013 Happened to me lol went for a bent mot with no horn and other things and ended up having a proper mot and a fail haha Ah! Im just lucky my dad does it then I guess! If there is something actually wrong then It wont pass but things like rear fog, HID's and horn etc... meeeh!
Nanglebadger Posted September 30, 2013 Posted September 30, 2013 i WISH it was that easy of here. would be schweeeeeeeeeeeeeeeeeeeeeeeeett! Phil.
Matt1878 Posted September 30, 2013 Posted September 30, 2013 i WISH it was that easy of here. would be schweeeeeeeeeeeeeeeeeeeeeeeeett! Phil. Im guessing NI MOT rules are much more harsh?
morgey Posted September 30, 2013 Posted September 30, 2013 Naa they just worry too much about it coming back on them I've had mot's with decats and have Said "I fitted that after the mot ;)"To which theyve replied "thats all I needed to hear"
Nanglebadger Posted September 30, 2013 Posted September 30, 2013 Im guessing NI MOT rules are much more harsh? they're government run, meaning there's no wiggle room for £10 and a crate of beer lol. Phil.
shorty Posted October 1, 2013 Posted October 1, 2013 Lol doesnt even need that over here just a sound mot tester, when i had my v with a front exit i wierdly had the same emmissons result as a pug307! Was suprised to be honest. Very eco friendly my v was.
Glanza-Ben Posted October 1, 2013 Posted October 1, 2013 (edited) Lol doesnt even need that over here just a sound mot tester, when i had my v with a front exit i wierdly had the same emmissons result as a pug307! Was suprised to be honest. Very eco friendly my v was.Never had an emissions test on any car lol and pretty sure a V don't need one due to laws Edited October 1, 2013 by Glanza-Ben
