Just disconnect the battery then remove steering wheel plastics 4x Phillips screws, the behind wheel is 2 screws undo them and pull the air bag then disconnect the wiring and put the air bag some where safe then use a 19mm ratchet to remove the steering wheel then refit the new one with boss kit
  On 9/29/2013 at 3:55 PM, Ballyhannon said:
Thanks airbag out. This is a ep91SR. I have an OMP boss fits on the splins Ok but how you connect the horn?
I wired my own switch in for the horn
You would either need to do this ^^^ of it is possible to get the connection from a none airbag toyota it's like a little brass connection on a spring which rides on the brass round on the back of the boss.
  On 9/30/2013 at 9:42 AM, Matt1878 said:
No one needs a horn :D... Unless your MOT tester is a tool and wont pass it 8)
Happened to me lol went for a bent mot with no horn and other things and ended up having a proper mot and a fail haha
Ah! Im just lucky my dad does it then I guess!
If there is something actually wrong then It wont pass but things like rear fog, HID's and horn etc... meeeh!
Naa they just worry too much about it coming back on them :p
I've had mot's with decats and have Said "I fitted that after the mot ;)"
To which theyve replied "thats all I needed to hear" :lol:
Lol doesnt even need that over here just a sound mot tester, when i had my v with a front exit i wierdly had the same emmissons result as a pug307! Was suprised to be honest. Very eco friendly my v was.
Never had an emissions test on any car lol and pretty sure a V don't need one due to laws
Edited by Glanza-Ben
