MIKEY4410 1998 STARLET SPORTIF TURBO--rear cambered terror------
Thanks j. no I was quite lucky and had good runs without issue.
I need help in sorting a proper effective intercooler mate.I have opened a new thread in intake,fueling section of forum
that needs to be sorted before I can do anymore track time.
45 degrees intercooler temps :-(
  • Replies 529
  • Created
  • Last Reply
Top Posters In This Topic
I have sourced a new radiator and also I have got hold of a second hand intercooler.
I have made my own brackets up for the radiator already
the new rad is a triple core and its 56mm thick.its monsterous.
the Intercooler is about 80mm thick and alot more substantial than the pajero one I currently have
mikey do some test that you do for the temperature on civic rad
i had awfull cooling isseus with 1 of them ( way to cold ) hard boosting my temp gauge only went to 8 o clock dropping to 7 while cruising !!!
now back to 9 while cruising with a oem civic 1
so today i fitted up the new intercooler and also the new rad , all with custom brackets.
first i had to angle grind the old mounts away / unbolt them
cleaned and then sprayed chassis
brackets lined up and bolted and lastly painted also
cleaned and re-sprayed the chassis
upper bracket fabricated,sprayed then secured
intercooler was to big,so i chopped the core very slighty and made it fit very well.
chopping intercooler
intercooler pipes are bit bodged for now as i used of cuts to make up new pipe.
hopefully my cooling issues are sorted
Edited by mikey4410
Just read all this thread got to say its amazing. I love your car bud! Wanted that colour starlet but couldn't find one close enough. Keep up the good work pal:)
Just read the while thread and i absolutley love this car awesome work buddy. One of my favourite starlets keep up the good work
small update on triple core rad
************30mph in fourth, ambient of 14 degrees gives rad temps of 84 degrees****************
Edited by mikey4410
now i have the better cooler thats alot more free flowing and bigger i want some real temp measurements from it so that i can see how efficient it is.
i will do this by having a sensor before and after the cooler,this will give an idea of what the coolers doing.
i tapped into the elbow thats just ONE INCH away from the turbo outlet.i used a bicycle valve and silcone to make a feed for the sensor. then made my sensor "body" out of an old vacuum t-piece.
this sensor will give an accurate view of temps from turbo BEFORE the cooler does its bit.
next up i need to fit the AFTER cooler sender......
Edited by mikey4410
yeah it reads well even as it is , but I am lowering it a bit more tonight as I know what u mean the closer the better.theres no way the air wont flow up to the sensor well as even now it changes temps very quickly.
cheers for the input colin ! :-D
so tonight I finshed modding up the piping for the sensor feed before and after the intercooler.
the ambient temp was 15 degrees,the pre temps were 19 degrees after a 10 second blast and the post temps were ambient so the intercoolers working well.I dont doubt the temps will get higher obviously on a trackday etc but i am much happier.
also did a periodic check on afrs and still bang on 11.00 afr wot till redline and boost also bang on at .90 bar.
:-D
