Beastmode panda Posted November 16, 2013 Posted November 16, 2013 Just went to take the glanza out to meet a few friends.. Off I go all was well, about 8 miles into my drive and I come off a corner and hit boost.. It popd and banged and hesitated then stopped and carried off but by then I had let off the throttle. I carried on, for some reason.. and eventually pulled over to see what was up, when I pulled over the idle dipped right down and was hunting from about 800rpm to 1000rpm. Sounded proper shit. I duno what the problem is!? All vac pipes are on, everything I can see visually is on and secure. The only thing I haven't done since putting the new engine is turn up the fuel pressure to what it was on my old engine (4 bar). It's currently on 3bar, so would that be the issue? The fact I boosted at over a bar of boost on only 3bar of fuel???? Running a jam fcd too if that helps anything. Limped it home, proper jank!! Idles rough and hunts the same. HELP!!! Quote
Kyle_R Posted November 16, 2013 Posted November 16, 2013 I got a very similar problem so would like to know aswell Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 I got a very similar problem so would like to know aswell I hope it hasn't detonated ;(((((( Quote
Kyle_R Posted November 16, 2013 Posted November 16, 2013 I hope it hasn't detonated ;(((((( same bud I'm running similar with a hks fcd Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 It's either det or pre-ignition imo. Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 Do you get eml?? No mate. by the way gap your spark plugs to 0.8mm with a feeler gauge!!! Then report back. Quote
Kyle_R Posted November 16, 2013 Posted November 16, 2013 No mate. by the way gap your spark plugs to 0.8mm with a feeler gauge!!! Then report back.whats the best heat range plugs as I'll change them at the same time they haven't been changed for a while Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 whats the best heat range plugs as I'll change them at the same time they haven't been changed for a while Go for heat range 7 and gap to 0.8mm. Quote
Kyle_R Posted November 16, 2013 Posted November 16, 2013 Go for heat range 7 and gap to 0.8mm.cheers bud Just went to take the glanza out to meet a few friends.. Off I go all was well, about 8 miles into my drive and I come off a corner and hit boost.. It popd and banged and hesitated then stopped and carried off but by then I had let off the throttle. I carried on, for some reason.. and eventually pulled over to see what was up, when I pulled over the idle dipped right down and was hunting from about 800rpm to 1000rpm. Sounded proper shit. I duno what the problem is!? All vac pipes are on, everything I can see visually is on and secure. The only thing I haven't done since putting the new engine is turn up the fuel pressure to what it was on my old engine (4 bar). It's currently on 3bar, so would that be the issue? The fact I boosted at over a bar of boost on only 3bar of fuel???? Running a jam fcd too if that helps anything. Limped it home, proper jank!! Idles rough and hunts the same. HELP!!!and back on track Sorry bud Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 cheers bud and back on trackSorry bud No probs hope yours is ok. I'm going to take out my plugs tomorrow and see what the gap is and take it from there. What kind of mods do you have and what turbo? Do you have an fpr? Quote
Kyle_R Posted November 16, 2013 Posted November 16, 2013 No probs hope yours is ok. I'm going to take out my plugs tomorrow and see what the gap is and take it from there. What kind of mods do you have and what turbo? Do you have an fpr?ive got fcd sld fpr hks actuator. Blitz front mount. Kakimoto exhaust decat and a zisco manifold (stock type) filter relocated with hks mushroom hks ssqv on a ct9b running 1.0 bar Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 Chances are your plugs just need gapping if you are having the same problem! I'm thinking the same for me, as I just went forged and the engine I put in I haven't checked the plugs yet and im running over 1 bar of boost on my garrett gt28 so chances are it's blowing the spark out where the spark is too long. I'll do mine in the morning. But I want to know why mine went really rough and is hunting :/ Quote
ryan lang Posted November 16, 2013 Posted November 16, 2013 i thought standard glanza fuel pressure was around 3.4 3.5? Quote
Kyle_R Posted November 16, 2013 Posted November 16, 2013 Chances are your plugs just need gapping if you are having the same problem! I'm thinking the same for me, as I just went forged and the engine I put in I haven't checked the plugs yet and im running over 1 bar of boost on my garrett gt28 so chances are it's blowing the spark out where the spark is too long. I'll do mine in the morning. But I want to know why mine went really rough and is hunting :/thats the thing I've built mine up to safely run 1.0bar until I can forge it and go standalone management and big power build.ill have a butchers aswell.i gotta check my turbo soon aswell as it's burning oil but not much and get a little oily puff occasionally and it don't like starting when warm either lol Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 i thought standard glanza fuel pressure was around 3.4 3.5? It's 2.4 isn't it? I'm putting my old fpr back on tomorrow cause I know its set to what it was before I put the new engine in with the fpr on. thats the thing I've built mine up to safely run 1.0bar until I can forge it and go standalone management and big power build.ill have a butchers aswell.i gotta check my turbo soon aswell as it's burning oil but not much and get a little oily puff occasionally and it don't like starting when warm either lol Cool man yeah just check the plugs are gapped first mate! Quote
ryan lang Posted November 16, 2013 Posted November 16, 2013 i think its up in the 3's dude. thats why my engines never lasted because of a faulty guage on my fpr. it was showing 3.6bar but only giving 2.7 so i was running really lean and killed off a few sets of ringlands Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 i think its up in the 3's dude. thats why my engines never lasted because of a faulty guage on my fpr. it was showing 3.6bar but only giving 2.7 so i was running really lean and killed off a few sets of ringlands May be 3.4 then man! My bad. Shit that sucks man, what fpr was that? Quote
Beastmode panda Posted November 16, 2013 Author Posted November 16, 2013 I thought it was 2.4 bar too. Hahaha, that's what I thought lol!! Quote
ryan lang Posted November 16, 2013 Posted November 16, 2013 it was a sard fpr im sure its more than that. not 100% though but my guage was definitely wrong haha Quote
Kingcarr Posted November 16, 2013 Posted November 16, 2013 I read it was 3 bar to 1 bar of boost, I also read to set it to 3 bar (without the vac hose connected) to be safe but it ran lumpy and bogged out in higher revs! My mate done a bit of maths, and worked it out and got it running perfect until I get my wideband fitted! Quote
AdamB Posted November 17, 2013 Posted November 17, 2013 Base fuel pressure is 2.3/2.4 bar.Are you sure you haven't popped off an intercooler hose? Thats what it sounds like to me. Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Base fuel pressure is 2.3/2.4 bar.Are you sure you haven't popped off an intercooler hose? Thats what it sounds like to me. I don't think so man, I checked them all but will check again for sure. And popping off an intercooler hose wouldn't make the revs drop and hunt for idle/make it run rough :s. Quote
