your probably running around stock power, depends what the other cars engine sizes were as to weather it is running as it should or not, maybe worth a compression test.
when you hitting full boost? is it holding or creeping?
my blitz wastegate diapgrahm is leaking, which is causing minor creep, ive got an electronic boost controller which seems to be doing well considering its a big ass leak, check your diaphragm on your wastegate.
EDIT: thought I read you were externally gated, ignore me LOL!
Edited by redz11
Just seem to be getting beat by every car and its dog. Have to change gear at 5000,rpm because of creep. Also have fmaf.
Changing gears at 5000 rpm doesnt help how much creep have you got? thought about poerting your wastegate so it holds boost better?
