Whitenoize Posted December 4, 2013 Posted December 4, 2013 Zisco offer them big money but looks like it would be amazing
daniel_g Posted December 4, 2013 Posted December 4, 2013 http://www.ukstarletowners.com/topic/71976-sold-fs-starlet-straight-cut-dog-box-kit-sold/?hl=%2Bthe+%2Bdemo+%2Bcar#entry909289
daniel_g Posted December 4, 2013 Posted December 4, 2013 TRD did a short ratio gearset, if you can still buy it new (which i doubt) then it would be dear as fuck. And theres pretty much no chance of finding a used kit, i know of one Glanza which had the TRD gearset but god knows what happened to it. Starlet gearbox options are very limited sadly :/
morgey Posted December 4, 2013 Posted December 4, 2013 Look through Wikipedia for a C series box with a close final drive and use that output shaft and final drive, will shorten all the gears.Or you could get a wider one to make all the gears longer.
Stu Posted December 5, 2013 Posted December 5, 2013 I had a TRD set years ago, but at the time couldn't be bothered ripping the box apart so it never got used.Moved workshops a few times and the box went missing - wish I had it now!
AdamB Posted December 5, 2013 Posted December 5, 2013 You can still get the TRD final drive with 4.7 ratio opposed to the stock 3.7.http://www.rhdjapan.com/trd-final-gear-set-starlet-ep82-ep91.html Will be a nightmare to drive on the road though. If its a stronger gearkit your after then TRD is no longer available, and the Zisco one is the only place to get one that's been ready designed.
5e colin Posted December 5, 2013 Posted December 5, 2013 if you want short gears go for the jdm el44 cynos B acis box there very close ( way closer then the corrola 4efe box ) there the closest box c152 she is
Phil Posted December 5, 2013 Posted December 5, 2013 if you want short gears go for the jdm el44 cynos B acis box there very close ( way closer then the corrola 4efe box ) there the closest box c152 she is take power ok boss? Phil
5e colin Posted December 5, 2013 Posted December 5, 2013 ^^^^^^^ hey amigo she took 5e tdo4 at 1.1 pritty wel got rid off it after to much wheel spin ( feul consumption ) i like long gears way better for a turbo car to take use off the torque this box is also not to be mistaken with the c152 from the ep71 turbo totaly difrent
