Id presume it would be the same as usual mate, under the front and rear subframe, if not then there should be jacking points on the side. Or even coming in from the side to go on front subframe, Just wherever is a strong structure that isnt in the way.
Hope thats usefull anyway mate.
Josh.
You should see 4 black rectangle pads on each corner on the sills. They are the jacking points. Some times the pads fall off so you might not have all 4
This, most BMWs are the same.
