Chops Posted December 13, 2013 Posted December 13, 2013 Hey all, finally got my shit together and finished my cars new turbo install, then found i was lugging a swimming pool about. previous owner had the same problem and told me he'd sorted it, there's rust in the boot that had been painted over and now the poor weathers set in its apparent he was a useless sack of shit at repair and at informing me of its problems when i bought it ):/. i know this is a common problem, and i have some mad sikaflex that can deal with it. anyone able to tell me where its getting in from, as i cant find it anywhere. In other news, i'm sick of having no rear wiper. its still fitted to the back of my car, but hasn't worked during my ownership. i dunno if it has water jets, or even how to use it cause my indicator stalks are so worn lol. anyone able to suggest a common reason why it doesn't work? Cheers for the help advice to those who gave it while i was pratting around with my turbo rebuild and manifold install i was gonna start a small build thread but my phone was stolen with all the pics on it, so it'd be a pretty boring thread lol Quote
Zeldoz Posted December 13, 2013 Posted December 13, 2013 I think it's through the top of the rear light water can get in from! There's a seal that can be damaged over the years and lets it in there. Drill a hole empty the pool and silicone it back up and repair as best you can! Checked the simple stuff ie - fuses for wiper? Quote
Ollieh17 Posted December 13, 2013 Posted December 13, 2013 i spent ages testing the boot seal, seals around lights etc, and found it was only seeping through the grommet in the spare wheel hole.Rain water was splashing up and gathering over time. Just a thought! Quote
Chops Posted December 13, 2013 Author Posted December 13, 2013 I think it's through the top of the rear light water can get in from! There's a seal that can be damaged over the years and lets it in there. Drill a hole empty the pool and silicone it back up and repair as best you can! Checked the simple stuff ie - fuses for wiper? theres a grommet dodad in my boot, got it all out with that and toweling. i do metal inserts on warships fro a living, so replacing the buggered metal is no biggie. i want to sort the leak first though lol! Quote
rmsnoel Posted January 2, 2014 Posted January 2, 2014 Mine was leaking below the rear light where the panel sealer had began to leak, its the silicone stuff thats painted over. A good clean, dry and bury it in silicone. Homebase/B&Q and get the silicone that goes on wet or damp surfaces.Usually its the figure 8 shaped seal around the rear lights has got dried up gunk on it which lets water past. Give that a clean first and reseal. Sit in a stripped out boot and have a mate with a garden hose pour it over the car Quote
fremyjay Posted January 3, 2014 Posted January 3, 2014 Mine was leaking behind the light where the weld joins, there was a lip and water seeped in there, siliconed it and no more water Quote
Rosso321 Posted January 3, 2014 Posted January 3, 2014 Very common problem get a bucket off water and poor on the roof and boot see were it goes and check boot before and after more likey the rubber seal around the boot it well worn mine leaks let out nearly 3litres the other day. I put it down to the rubber seal and around te tail lights. Quote
mattyD Posted January 3, 2014 Posted January 3, 2014 Mine has a leak on both lights, turns out it's the top rubber seal on both of them I have now ordered all new seals so fingers crossed it cures the problem Quote
Chops Posted January 3, 2014 Author Posted January 3, 2014 ima hit it with some sikaflex, demolish any leaks. whats the black shit that holds the plastic sheeting on doors in? my old micra had tonnes of that stuff round the lights, never leaked a drop. Quote
Turk Posted January 14, 2014 Posted January 14, 2014 I put tigerseal on the seal and put my lights back on. Its worked for me on oneside. But im still getting little water on the other. Is there anywhere we can get the seals for the lights. Also does anyone know if toyota supplies thema nd how much? Quote
Mel85 Posted January 15, 2014 Posted January 15, 2014 mine was a leaking seal/grommet on lights AND the grommet for cabling at the very top of the hatch where the wire for and LED brake light runs into the hatch itself. i had the entire boot floor out of another starlet GT welded in at the seams so i was quite determined to find what had nackered the previous incarnation of the boot! needless to say i've hammerited treated the entire boot floor section to prevent any further issues and siliconed across welds behind the light clusters. Quote
mattyD Posted January 15, 2014 Posted January 15, 2014 The seals can be got from toyota, I got all four for about £80 I think....... Quote
mikey4410 Posted January 20, 2014 Posted January 20, 2014 I am currently working on a gt and it has the same issue. I have put a little tigerseal round the poppers on the grill/vent that sits next to the rear window on an ep82.also put a new seal/grommet in under the light an also re sealed inside the rear quarter that suffered leaking as the old factory sealant came away a bit. When I get home tonight I am gonna bucket of water the rear of the car to check the water tightness Quote
crazy_eyes Posted January 20, 2014 Posted January 20, 2014 i noticed this in mine last week, mines been stood for a while and boot was full of water, ive towelled it all out and sprayed the entire boot floor in Galv spray, gonna follow this thread and try and sort my leak out Quote
mikey4410 Posted January 20, 2014 Posted January 20, 2014 this starlet in am working on has finally stopped leaking.all the wheel well is sprayed up and boots now dry and awesome....if unaddressed this would rot ure car from inside out wont it.at least thats over .on to next jobs Quote
akyakapotter Posted February 10, 2014 Posted February 10, 2014 Mines starting to flll up with water only place it's wet us just under the lock going to investigate tomorrow and get the skiflex out Quote
dangeestarlet Posted February 10, 2014 Posted February 10, 2014 Mines the same the wheel well was full Quote
