PAUL7 Posted December 16, 2013 Posted December 16, 2013 where can i get a abs removal kit and what are the best drilled and grooved discs? Quote
Jamie_VF22 Posted December 16, 2013 Posted December 16, 2013 Tuning developments does the ABS removal kit buddy EBC drilled and grooved discs will do the job lad Quote
Keri-WMS Posted December 16, 2013 Posted December 16, 2013 Or (grooved) WMS 110% heavy duty discs and Ferodo DS2500? :-) Quote
Chris_GlanzaV98 Posted December 16, 2013 Posted December 16, 2013 Td do the abs removal kit, im useing it, not tested it out properly with my ksports yet though only used it on street Quote
Chris_GlanzaV98 Posted December 16, 2013 Posted December 16, 2013 You changing from kaport discs mate ? Quote
Chops Posted December 17, 2013 Posted December 17, 2013 Why remove abs, i often wish mine had it. :L Quote
SiCaln Posted December 17, 2013 Posted December 17, 2013 I always found mine chipped in too early and at times when it was unnecessary, always felt more confident without it and a good brake set up Quote
TurboTobz Posted December 17, 2013 Posted December 17, 2013 I had an abs fault once cause me to lock up and slide at high speed never again wouldn't catch me removing it Quote
pick1 Posted December 17, 2013 Posted December 17, 2013 Or (grooved) WMS 110% heavy duty discs and Ferodo DS2500? :-)What's the damage on them then Keri ?? Quote
Keri-WMS Posted December 17, 2013 Posted December 17, 2013 What's the damage on them then Keri ?? Have a look here ( http://www.ukstarletowners.com/topic/72471-discspads-for-toyota-calipers-inc-wms-110-heavy-duty/ ), they are only for the OEM caliper though, not for anything K-Sport etc. Quote
Jamie1st Posted December 17, 2013 Posted December 17, 2013 I had an abs fault once cause me to lock up and slide at high speed never again wouldn't catch me removing itAt least when it's removed you'll know it's deffo not there!My ksports are shit with abs plugged in, just removed fuse for now Quote
