iamlegend Posted January 2, 2014 Posted January 2, 2014 any ideas with a slight burny smell in reverse gear?? its like a light smell of burny stoney smell lol... happens in reverse gear only.. drives spot on just a tad smell when in reverse Quote
TurboTobz Posted January 3, 2014 Posted January 3, 2014 Neighbours cat on the underside of your car? Use mirror next time. Quote
daniel_g Posted January 3, 2014 Posted January 3, 2014 ^^ haha.Is this your Ibiza yeah ? I'd check the autobox oil, colour, smell & level, infact i'd probably juat change the oil. Quote
iamlegend Posted January 3, 2014 Author Posted January 3, 2014 The gearbox is sealed for life LOL!!So can't change the fluid That's alittle daft....It only happens in reverse sometimes Quote
kavan-k Posted January 3, 2014 Posted January 3, 2014 Put it in neutral and push it backwards lol if It was the fluid would the forward gears not be the same? Quote
Addymk2 Posted January 3, 2014 Posted January 3, 2014 Something burning off your exhaust? When in reverse it might just be enough to let it waft in?Is it a new exhaust? Might have a protective coating burning off/into the metal. Quote
daniel_g Posted January 3, 2014 Posted January 3, 2014 The gearbox is sealed for life LOL!!So can't change the fluid That's alittle daft....It only happens in reverse sometimesOhh well haha, theres a VAG Tech on here im sure, cannot remember who though lol.Put it in neutral and push it backwards lol if It was the fluid would the forward gears not be the same?Some Autoboxes have different compartments, if oil wasnt getting into where it should be or overheating in a specific place it could cause a burning smell. Quote
Amjad Posted January 3, 2014 Posted January 3, 2014 Ohh well haha, theres a VAG Tech on here im sure, cannot remember who though lol. Might be Glanza Ben with the Black V Quote
Glanza-Ben Posted January 3, 2014 Posted January 3, 2014 You can only have the oil changed if the box has had some work done on the 7 speed as it's a lifetime oil in there, my old dsg polo gti use to stink every now and then as the wax on the bottem of the car use to burn Quote
iamlegend Posted January 14, 2014 Author Posted January 14, 2014 all sorted was a split o/s inner cv boot seal had failed! that stuff bloody STINKS!! woohooo Quote
