ePurchased a mk1 gt last week and it was a little rough so I'm now breaking it and just bought this little 5 door sportiff , 60,000 miles 2 owners full service history , so my plans are to keep it looking standard except for some wheels and turbo the beast , updates to follow
C675D871-B55D-4820-A29E-CEFFE76628AE_zps
FE143556-1929-460C-93A0-D1D9A1B6C002_zps
Edited by dangeestarlet
  • Replies 184
  • Created
  • Last Reply
Top Posters In This Topic
She is clean fair play, only paid £430 for it, will start swapping engines over but first I need to find out if my mk1 loom will be easy to put in the n/a
That looks clean mate !!
And yeah i gotta agree with Aamir about the looms, ive done the conversion on a 85 using some 82 looms from a GT of the same year and it just made everything so simple, all the plugs lined up, no splicing and tracing wires and no headaches haha.
Best bet for you would be to get a 96spec set of looms.
I don't have one for sale unfortunately, you will need engine loom, dash loom, ecu and all the interior loom. You will have to hardwire the fuel pump too or you can just change it to one from a Glanza
Youd need a Glanza ECU yeah, you might be able to use some stuff of the MK1 like the ignitor/coil, MAP sensor, inlet mani/TB. I believe the dizzy setup on the MK1s was slightly different but you might be able to put a clip type cap on it, you'll need a Glanza thermostat housing aswell.
Basically just swap most of it out for a FTE setup of the same year.
There are other ways to do the conversion using a spliced in GT loom but i've never done it..
Would be easier just to buy a Glanza one to save you the headache. Contact Zeldoz, his breaking his silver Glanza shell
Yeah, I had to do the same mate. I had to remove all my Glanza wiring loom to put an n/a wiring loom in. It's a ballache
Yeap will be a headache making it into a turbo but will be worth it, plans are :
Fit my sparco wheel and boss
Clear indicators
Lowered all round
Set of alloys that I had on gt
Gt front brakes
Turbo conversion
Fit my Oem strut brace
Fit my oil catch can
And see how it goes :)
i would keep the amber corners, more standard :) and the trims look even better, it would be one of a kind if your trims fell off due to the turbo :D
Edited by Jamie5414
Proper sleeper spec lol, another update just purchased a full glanza wiring loom and wiper stalks, all I need now is a ecu and should be ready to be put it :)
Nice project, I'm guessing you have some already but if you're after some front GT seats gimme a shout!
I ain't got none , what sort of price we looking at? Cheers
Update, fitted my wheels today and gab rear adjustable shocks and springs, just need a set for the front now also fitted my sparco steering wheel and front strut brace and I'm going to try and get it all up and running for japfest :) pics to follow tommorow
