  • Replies 92
  • Created
  • Last Reply
Top Posters In This Topic
Slowly all coming together now! Rebuilt my 460cc injectors :D
Going to paint all my engine up so it's nice and fresh so took power steering pump off for a clean and spray
Fitted both the front and rear arb and my hks exhaust :D
Nearly already for my new zisco externally gated mani kit :D
Another Update for you guys............
After sourcing a lot of parts and speaking to Keith at Zisco i decided to get the car ready so i can start getting it on Track and maybe do some of the last session of the Toyota Sprint Series :clapping:
With the great help of both Keith, White Noise on here and Tuning Development i managed source the following Parts.
While waiting for Keith to do his magic i thought ill get the engine looking as good as possible and ready for the new kit! What a nightmare i had removing the old exhaust the bolts had been rounded off and rusted on! (car had been sitting for 2 years before i brought it) I got to this!
So tonight it all began! I decided i would get the kit on as best as possible and noticed that i have come across 2 problems. 1 being the water pipes to the turbo are hitting the creamer pipe (going to get heat wrap for the pipes) and the oil return had moved from the standard position so need to order a 90 degree bend slightly longer then standard that i can cut down and make work!
And decided to fit my C'S Short Shifter :thumbsup:
Spec List at present!
Engine:
74.5 mm ross forged
pauter rods
polished and knife edged crank
lightened pulley
all new bearings and seal
new cam belt
2mm Multi Layer Head Gasket
Fueling
470cc Injectors
255l Walbro Fuel Pump
TD High Flow Fuel Rail
Sard FPR
Cooling
AutoBahn Front Mount Intercooler
Alloy Civic Rad
Relocation Air Filter Kit(Come out just behind grill)
Turbo:
TD04 Hybrid Lateral Performance
Full HKS Hi Power Exhaust System
Up Rated Exhaust Hangers
Zisco Cruise Manifold Externally Gated
Turbo Smart Wategate
Zisco Screamer Pipe
Zisco Decat
Transmission:
spec 6puk paddle clutch
TD Light weight flywheel
C's Short Shifter
Electronics:
E-Managed Ultimate
Depo Racing Oil Temp Gauge
Depo Racing Oil Pressure Gauge
Depo Racing Water Temp Gauge
Start/Cut off switch
Fan toggle switch
Fuel pump toggle switch
HKS EVC 6 Boost Controller
Chassis:
6 Point Carbing Roll Cage
Polycarbonate Sunroof
BMW E30 Wheels
Cusco Front Strut Brace
Poly Engine and gear box Mounts
White Line Front Anti Roll Bar
White Line Rear Anti Roll Bar
BC Coilovers
RSR Pan Hard Rod
Brakes
4 Pot Wilwoods
Braided Lines
Vented and grooved disc
Yellow pads
Comments Welcome!!! :yahoo::yahoo:
Super stuff lad :)
Phil
Cheers Phil! Getting there mate hopefully all will be ready for base map in next couple of weeks if all goes we'll and full map end of June see what power she's pushing :D
Right guys i may get to the stage of the base map soon but i keep choosing to do more bits :yahoo:
Picked up my Emanage Ultimate & Gauges of WhiteNoise on Friday. As i was having a look through the old Dasteck Unichip they had spliced into all the wires so it all begun putting it back to standard plugged the harness to the ecu and field harness and mounted the EMU in the glove box ( Just waiting for a 3 bar map sensor from Tuning Development)
Then i decided that i didnt like my old Gauge pod that i made so i went about fab a new one up! sending away today for flocking.
image_zpsfff69c50.jpgReady for
Flocking! :p:thumbsup:
I was then told by abbott that he was going to see Dean did i need anything done so thought i might aswell get my fitment weilded on :yahoo:
Hope you enjoy! Quality work as usual from DEAN @RW :D
Only just seeing this now mate some great work can't be far off now? that turbo kit looks awesome I can't wait to get back and start a build after reading this ..keep up the good work man :)
Edited by Whitenoize
love your center consol fancy making an other? :p lol
Lot of work man nearly a full day! Might start trying to make carbon fiber I'll let you know if I do! Or send me a spare one and as I have time I'll do it lol
Hello mate
No not too far off now! Need to still
Make braided line for rocker and catch can
Spray rocker
Fit it all
Braided fuel line to go on then prime the fuel to check I have no leaks
Fit map sensor
Braided clutch line
Exhaust/decat gasket
And earthing kit
Ooooo and assemble all my center consol when it comes back
So not much ;)
Lovely jubly.wicked work
Cheers mikey
Got my center console back from the flockers so put everything back together! Slowly getting there hopefully soon will be ready for mapping.
Enjoy :D:D:D:thumbsup::thumbsup::thumbsup:
ello pal how did you cut the holes in that carbon fibre panel??
Hello buddy! It wasn't carbon fibre I carbon wrapped it! Laser cut it as do all that sort at work! Anyone need bits done just pm me :D
