Hi peeps :) I think my tyres are rubbing inside the arches, only happens when your near to turning on full lock, anything I can do to stop the rubbing? :) wheels are 15" 8j et0
Must be the inside as it's not lowered, do you know where i can buy wheel spacers? :)
It might be hitting the outside on bumps. You on springs? Get some live sports wings on the front , you could get some over fenders on the rear.
Yeah only on springs, I've ordered some wheel spacers to see if that helps, they don't stick out to far tbh so hopefully won't look to stupid :)
I run 8.5j front wheels and the only thing they scrub is the arch liner ( because of the ride height) Unless the ep82 arches are different i cant see how itd hit the inside?
Edit: Actually, i run 195/45's, i suppose it depends on the tyre size really
Edited by dan106
15x8 et 0 ... Would they rub?
In all seriousness when u run a wheel that's offset is -35 from standard u really must expect it lol
Edited by MARC MOSS
