sophiealice Posted March 27, 2014 Posted March 27, 2014 I will be driving fine on normal roads soon as i go on the motorway and hit 80kph the car will bang and just jerk really aggressive aswel and then the engine management light will come on. I been told of a few people it will be a fuel cut. But it never use to do it till i put a new ct9 turbo on it ? Quote
H_D Posted March 27, 2014 Posted March 27, 2014 sounds like fuel cut,Have u done a diagnostic check? Quote
Socks Posted March 27, 2014 Posted March 27, 2014 Sounds like Fuel Cut to me! It will be overboosting... So if you have an adjustable actuator/boost controller. etcYou'll need to adjust to suit.. What is your full spec? Quote
richardc9052 Posted March 27, 2014 Posted March 27, 2014 Did you use the same actuator of your old ct9? are all the vacuum pipes fitted where they should be? Quote
sophiealice Posted March 27, 2014 Author Posted March 27, 2014 Nope not done a diagnostic check on it yet i not got adjustable actuator or anything yet the car still completely standard. Its same actuator as the old one which is on it. Quote
Socks Posted March 27, 2014 Posted March 27, 2014 Overboosting on a stock car.... Interesting! 100% sure? What is it boosting too? Have u got a boost gauge? Did you use a actuator off your old turbo? Quote
Dean_mc88 Posted March 27, 2014 Posted March 27, 2014 actuator hose leak possibly ? that can cause overboost Quote
sophiealice Posted March 27, 2014 Author Posted March 27, 2014 I not got a boost gauge well i have but haven't got it in yet. Yea kept the same actuator of the old turbo. When we fitted new turbo we realized it was different to the old turbo. The new one had a lip on the end and the old one didn't but they both ct9 think it to do with that ? Quote
sophiealice Posted March 27, 2014 Author Posted March 27, 2014 Ye on the intake i did look on the internet but most pages said jt was the updated version of ct9 Quote
Socks Posted March 27, 2014 Posted March 27, 2014 Got some pics?Possible Hybrid maybe? Boost Gauge are essential to monitor boost pressure!Would also tell you straight away if it was FCD as you'll be hitting 0.85bar plus... Quote
sophiealice Posted March 27, 2014 Author Posted March 27, 2014 Ill get sole.pictures up this afternoon for you too see. I need to get my gauge in just need to fond a stand thing to sit it on or something. My dad had a thing which you plug in and pass wite through window so you can drive it and test pressure and everything and when we did it it was boosting at about 0.6but ill try get the gauge in soon as possible so can see what jt actually boosting Quote
Dean_mc88 Posted March 27, 2014 Posted March 27, 2014 I have a hybrid ct9 that has a lip and I have a standard ct9 that has a lip Quote
sophiealice Posted March 27, 2014 Author Posted March 27, 2014 The old turbo didn't have a lip the pipe to the intercooler just slipped straight on it easily and this new one was a bit of trouble to get on because we had to try get the pipe over the lip Quote
Socks Posted March 27, 2014 Posted March 27, 2014 DId you test all Gears. You'll always build more boost in higher gears on a ct9! Quote
sophiealice Posted March 27, 2014 Author Posted March 27, 2014 Yea tested them all and they was all the same Quote
ashSublime Posted May 6, 2014 Posted May 6, 2014 This sounds similar to what I'm having at the minute, fine boosting through 1st/2nd then change into 3rd and it starts juddering on boost then cuts out about 5000rpm and I get a loud pop/bang when I come off the throttle, I'm on standard ct9 with an adjustable actuator, boosting at .6 but as I get through the gears I've had .8, obviously wondering what it is but I'm also concerned whether it'll be causing anymore damage? When I bought my car my precat lambda was cut and a couple of friends of mine thought it could maybe be down to that, I have another waiting to go on but I was wondering if it could be fuel cut instead? Quote
patman Posted May 6, 2014 Posted May 6, 2014 (edited) I had this before now we all know fcd's are not the way to go but my fcd was set to 12 at the time, set it to 8 with a sard fpr also went to dyno to have it set up right, make sure fueling was safe etc and everything was good 👍 had it set up to a safe 0.8 bar Edited May 6, 2014 by patman Quote
corofin12345 Posted May 7, 2014 Posted May 7, 2014 the answer to your problem is given in the fist reply on this thread... your engine management light came on indicating a problem... we can all guess till the cows come home but the answer lies in the stored code in the ECU... do the diagnostic test and that will tell you why the engine management light came on.. yep its that simple... not ruling out fuel cut but the symptoms dont add up to be a fuel cut... you mentioned it happens at 80kph.. fuel cut can happen in any gear at any speed and in any rev... this is why i think its something else....... do a diagnostic test... i suspect code 52, knock sensor.. but who knows till you do the test Quote
Cushion Posted May 7, 2014 Posted May 7, 2014 Sounds like fuel cut, had the same problem on mine when I first got it and it was standard (besides hks air filter). Would only happen on really cold mornings (3-4:00am) and it turned out to be the actuator was knackered. Spring wasnt holding pressure. Got a hks actuator and all was fine Quote
