Ollieh17 Posted May 12, 2014 Posted May 12, 2014 Had my tf035 on for a week now. Was playing last night with my mates in their scoob and evo. After that boost started dropping off and coming in later and later. Taken the pipes off and cant see holes. Had this before and turbo had blown. Someone tell me im missing a leak from somewhere and the best way to find it Quote
MARC MOSS Posted May 12, 2014 Posted May 12, 2014 Have you taken the pipe off the compressor wheel and spun the turbo? Quote
MARC MOSS Posted May 12, 2014 Posted May 12, 2014 And how about your actuator? Is the wastegate stuck open,? Quote
Jamie5414 Posted May 12, 2014 Posted May 12, 2014 (edited) Socks mentioned a good way to find any leaks, I can't remember where he posted it though haha, maybe he will post in here Edited May 12, 2014 by Jamie5414 Quote
karl. Posted May 12, 2014 Posted May 12, 2014 (edited) I thinks socks method was to hold your hand or something to block the intake of the turbo. If there is any leaks u will hear them. If the car stops then there is no leaks Edited May 12, 2014 by karl. Quote
Liam_D Posted May 12, 2014 Posted May 12, 2014 Take air filter pipe off and give the turbo a wiggle Quote
Ollieh17 Posted May 13, 2014 Author Posted May 13, 2014 Im externally gated, wastegate seems fine as nothing is coming from the screamer. Will take the air filter off and check for leaks tonight. Cheers guys Quote
Liam_D Posted May 13, 2014 Posted May 13, 2014 You don't have the wastegate pipes the wrong way round do you? Quote
Krissyb Posted May 13, 2014 Posted May 13, 2014 (edited) How long have you had the turbo on for and how many miles has it done, who'd you get it off of. Edited May 13, 2014 by Krissyb Quote
Ollieh17 Posted May 13, 2014 Author Posted May 13, 2014 Nope everything was fine boosting and holding 0.7. Then got laggier, now no boost at all until like 0.2bar at 5krpm Quote
daniel_g Posted May 13, 2014 Posted May 13, 2014 I was having very similar issues, turned out to be the seal around the EWG, my boost ring thing was loose. Feel the turbo for play, check intercooler pipes and joiners, check core for leaks aswell. Could whip off the decat and look for fucked oil seal. You can buy EWG blanks on ebay which you attach to the mani instead of a EWG, it will rule out a faulty EWG as it bypasses it, but you will technically be running unlimited boost whilst testing. Quote
Ollieh17 Posted May 13, 2014 Author Posted May 13, 2014 That would make sense, its a vband wastegate and did have diffculties fitting at first. May be that its come loose. When i had leaks before from the manifold the sound was different Quote
daniel_g Posted May 13, 2014 Posted May 13, 2014 Ahh yeah i've heard of v-bands working loose before, i dont really trust them. Hopefully thats the issue and its nothing serious. Quote
Ollieh17 Posted May 13, 2014 Author Posted May 13, 2014 Cheers bud. I hope so too, turbos awesome and they are hard to come by Quote
Ollieh17 Posted May 14, 2014 Author Posted May 14, 2014 Shitty weld on the wastegate had broken, all sorted now Quote
