  • Replies 189
  • Created
  • Last Reply
Top Posters In This Topic
Wow! You know things are serious and every little detail matters when the bolts get zinc coated! Love it keep it up man!
So true man, so true :cray::cray::cray:
Is that the Subaru with the bad-azz engine? :)
Hw do u end up with split boots?
Edited by jiggaman_16
Haha I priced a cv boot in toyota not long ago, got a right scare!
I know I sucks don't it! At least I won't have to worry about them in the future!
Some serious work hear lad
Keep it up
Thanks buddy
Nah don't think so... These came with eg33's... 3.3 N/A
What do you mean the new or old ones? The new ones come with some sort of resin to glue them together
  • 2 weeks later...
Had a nightmare with the CV boots this weekend after purchasing them from Toyota with the chassis number they still turned out to be wrong, no surprise there! After a lot of phone calls to and from the dealer we concluded the the inner ones are no longer available 😡 much to my disappointment as id already started to fit them! Rather than wasting £50 odd for them I though of a solution, the cut outs in the cup were the issue so I attempted to fill those and continue fitting the new boots
F0FFA9F3-6FA2-4873-AA7D-C08C0EA42155_zps
This is the one I tried to repair previously as it had completely split and covered my bay in grease!
88772EBA-8832-4E93-8A83-F3FBF2EE4B1A_zps
A5BBC07C-CDCD-4342-A39B-135C927BD40B_zps
Here's the solution we come up with to try and get round it... Opinions/Solutions/Criticism welcome...
Using a plastic bottle I made a circle shape to contain the abro steel while I was working it in. I chose to use this as I've had good experiences with it before and I'm able to remove it if it doesn't work out.
A36E36F2-297C-4E28-83FB-6998C90CF929_zps
9FA59B33-910F-4EC5-9F8C-8E922C0C7467_zps
CE1F554B-F30F-4DEF-821C-C35ABA9858D4_zps
A60C8324-EED8-46B6-BBB6-AD51504C13D6_zps
0EB5A252-9E9B-43AF-88F3-05C85C71685B_zps
Once they've fully harden I'll clean up the excess, file the inner edge completely smooth and cut 2 small groves in them so they boot will fit properly. Fingers crossed!
Got my rear lights fitted though 😊
14E436CB-2D6C-43A7-8D81-1ADB7D1C17EA_zps
7BA9BF12-8504-407C-86C7-1A06D6400C62_zps
152BB99C-9178-41AA-9160-00AAD0348CB7_zps
So weird I fitted my fears yesterday exactly the same, removing mine tho as I don't think they suit the sr. Good progress mate you're getting over these hurdles well
She's looking lovely mate :thumbsup:
Thanks mate!
Great minds think alike 😛 oh no not a fan of them? I'll check it out in a mo! Cheers mate, struggling to find the motivation again though 😔 I'll post the to do list later... It's not getting no smaller haha Edited by Scoobysvx
Ha ha it's like any project I guess you just keep finding more things you want to do. If I had a spare 5k I think I could blow it on the car in a couple of days easily. Not surprised you lose a bit of drive now and again as it seems like you've had a few obstacles a long the way. Are you going to be the first person on here to try the longer final gear mod?
Began the job of cleaning up the cups and getting a grove cut into the new part for the boot to fit
36EC87FF-FE94-4C69-813E-4C646EFDC0BE_zps
98F7649C-C76D-40B0-A9B4-BE336C499EFC_zps
B0E80609-A64D-4AB7-AE55-98E180220954_zps
4C8A9AB6-AF6E-4F61-85BE-277AA1632CB3_zps
Test fitted the boot using the old clip. No grease will be getting past that
47377D25-9EA5-4E4F-B87B-E65A2D75DD56_zps
52DD0055-BC3B-44BE-BDF9-83645E19F3FD_zps
Primed and painted
D4267FF4-BC05-4BBB-A005-64D0FE02F7D2_zps
43638F7D-720B-43C9-AEAA-56A8DFA7E20C_zps
Will post pictures up of the other side when I've got some more black paint! Really pleased with the outcome though 😊
Yeh you've got that right, like any project there never 'finished' lol I'm sure we all could jase, if only 😛 Yeh it's so close to being road worthy now, I need to pull my finger out! That the long term plan yes, hopefully in a couple of years I'll completely change the drivetrain, IRS subframe and different gear ratios
Well I'd definalty say that getting it on the road and enjoying it is in order :) I think you'll have bags of fun. Even though I've got no power at the moment I love driving the sr, just puts a smile on my face
  • 2 weeks later...
No real updates atm due to a few other projects but I have managed to source the long lost items!
Throttle cable bracket that's goes onto the inlet, wire wheeled and painted
87C15A19-4084-443B-BC35-0C114AED3EA4_zps
B96B15C3-EA6F-4322-86C1-252ACBDE1206_zps
7E6039E4-DAD1-4797-A108-8A9F8E5BD880_zps
E0058781-DB21-45D7-B2DD-513A89A3C5D7_zps
Also got a O/S headlight as my last one got burnt in a small garage fire 😢
It's in pretty good condition as it is but I'm just waiting for marco to polish it for me 😂
80EFA6A2-0F25-49D4-857F-67E8AFB522F6_zps
917F9974-9D75-488E-8292-F10EF1E7E531_zps
Here's the remains of the burnt one... I was looking for the other headlight for about 20 minutes while my dad was grinding away in the garage... Then I come back in to find a pretty big fire and the headlight I had found melted into the orange box 😕 And as you can guess I found the other headlight about 10 seconds after we put the fire out😡
600D59B3-0B56-4ECF-8937-37158BC1B404_zps
  • 2 weeks later...
So what do you do when you've got an unfinished project... Buy another one :p I recently purchased a Glanza with low compression. After a strip down it was clear to see what was at fault! Time to rebuild the head :)
F04B5931-1E8E-414C-9ECC-0590F2CB6677_zps
08CB61E4-85A1-4718-9688-5DB626BDD6B8_zps
Various parts cleaned up ready to be refitted
BE08C0C3-6754-4A5A-88ED-0211D1AF3D0C_zps
Back from the machine shop from having the head skimmed... Note the build up on the exhaust valves
81D8C5E6-0A1E-45C7-9D41-A1A03932F802_zps
De-coked all the valves
B080FE54-5B85-477E-A07B-ECF2210D7747_zps
Lapping the valves back in and installing the new valve stem seals 😴
DB94594D-9AED-4FFB-A4AA-F7C95D85B2D6_zps
4E8C9338-390F-4F56-BDD2-B27DC2FBC4EC_zps
First valve back in!
A52F9333-34C5-4C0C-AA36-9882C7609516_zps
All lapped in and looking clean!
71204700-BFC6-4022-BF28-447D59945E65_zps
Finished up with a fresh lick of paint :)
A1FF858E-8C01-4BA2-8CE9-92F0671827B7_zps
CAF80FC5-0DA4-41FB-98A2-4752015593AE_zps
B42819CC-FD83-4FC3-B4DA-BEC9168278AD_zps
2ABB200B-D8E3-4B2D-9EEF-0B1069CEF9FA_zps
C858ED20-C94B-4705-98C7-B1064E2FD72B_zps
Really pleased with the results!
  • 1 month later...
I finally got round to mounting the Pas pump this weekend and making the lines from the rack. This gave me a chance to offer up the wings and bumper finally :D
609C4929-2461-4910-ACE7-64E942FD8B7E_zps
Nothing's bolted up properly hence the gaps and bumper is a little misshaped due to be sat in my bedroom for 2 years and never being fitted! All will be good once bolted on though!
252EBCE0-3032-4081-BF3E-38E0D09E3F66_zps
F4BF9903-D948-4A48-9C00-5456F5F647A2_zps
24561DEA-2930-4C60-B270-84C0F7AC8482_zps
Should look spot on once the skirts are fitted and the cars lowered some more! Power fold mirrors fitted too.
Also managed to remove the EMB and repair the loom in readiness so I can use the powerfc to start the car and know it's all okay before I change over to the link ECU.
Wiring for the Oil pressure & temperature gauge run into the cabin ready to be fitted once the dash is back in.
I'm hoping to get the fuses and distribution box sorted in the next couple of weeks so the battery can be mounted in the boot and once the oil return is fitted she should be ready to fire up!!
Still lots to be fitted though!
  • 2 weeks later...
Thanks guys
Currently trying to figure out who to map the link ecu, it will most likely end up at race-tech to be fitted, run in and mapped hopefully within the next 6 weeks Just waiting on some parts to get the battery wired up in the boot properly. Still need to sort the oil return before I can fire it up though
  • 2 weeks later...
I tackled the never ending job of the power steering pump this weekend... I sure hope it works faultlessly when it's up and running after all the time and effort that's been put into it! Wiring now complete with a heavy duty multi plug installed, just need to get some high pressure hose to run to and from the rack and job done!
E302BF69-2B69-4798-860D-4C1FE4157597_zps
1591FAC8-F6A1-4BC9-8008-5E7190873B65_zps
I managed to get all the small annoying jobs done... Clipping the loom into place around the headlights and wings. Installed the pressure sender and sensor for the oil gauges.
68E0B428-BE34-4954-9B12-15021C619DD0_zps
7374116C-5498-48E3-BA4F-C774B31D3ED6_zps
EAF51A79-CAB0-4BF2-BCEA-89E87BAAA159_zps
Got the oil return sorted for now! Unfortunately things have started to rust due to it being sat outside for so long :(
A362BBFB-5DD0-4E7A-8E55-C04D784B8A1C_zps
Heater pipes fitted too
EC37F489-6377-4122-9696-41FDB06FBBA0_zps
Ran the wiring for the boost solenoid which I mounted under the slam panel and ran the vac pipes
55EB802D-A975-443D-A3BC-66C7ED6092F8_zps
I got all the vac pipes sorted, Dv, map sensor, gauge etc.
D9A301EA-6B01-4FA6-AEC5-FC4570076616_zps
Throttle cable bracket on too
D5BF2A96-69FD-433A-A82D-04C9022DED39_zps
Intercooler refitted again!! Doesn't look like much has changed but tied up a lot of loose ends :)
BF7C4950-F839-48AF-8BCD-DB1D758CAA6B_zps
Cleared out the interior too not that you can tell 😂 and also got some more sound deadening.
D6B96954-79C9-43A1-A165-DB96182DDBC4_zps
C09C089E-5666-49DF-A1F0-CA669EBF1F76_zps
Unfortunately I need a couple of small things before I can start it which I forgot about... AN Union for the fuel filter and braided clutch line. I got an inline fuse and power distribution box as the battery's going in the boot.
532CBCEE-D84D-4FB1-86ED-A8642FE7659D_zps
9D3443E7-DD32-4FE2-8661-D3F641B33443_zps
Hopefully there'll be some significant updates in the near future! :D
Mate they were significant updates! It's always the little things that take ages. Bet you can't wait to actually have it back on the road. Oh by the way, do you have the plastic adjuster cog for the 98 spec seats?
Damn that car is sweet, good work :)
By the way, turbo return hose rubber? If is, it won't last long, be carefull, huge fire risk...
Yeh mate you've got that right! Hopefully things can start moving forward a lot quicker now :) You don't understand, it's been about 18 months now :/ Yeh sorry buddy I'll drop you a text later!
Thanks mate! Yes it is a rubber hose, just a temporary fix so I can get it running, I'll be getting a silicone one soon :) ... That'll be the last thing I need!
  • 3 weeks later...
Some small updates for now...
I ditched the smaller clutch line and had a custom Hel one made from the master to the slave
1350B514-24CF-4EE4-9BEE-12FE76EE511A_zps
Also sourced the hose for the PAS, fuel filter fitting and steering wheel bolts
ED7735D3-9D21-4C09-A30E-3C696622B6E0_zps
E5F31D14-440C-41AA-947D-508F6F4A522A_zps
99A1403A-6B26-4A89-9291-302653A4A0CC_zps
8FC0D39A-977F-41DF-9F60-7CB0DFFA6BCB_zps
F1F3E986-C5C6-4D75-8410-0C339B2D4A05_zps
Fuel rail connected to the filter now but I might get a right angle fitting for the filter as I'm not too happy with how it is atm
D42C27F5-8CE4-488A-82D6-AF6FAD110601_zps
Running the clutch line against the bulk head P clipping it to the fuel filter, still need to figure out where it's going on the front of the gearbox but I need to finish the wiring there first
20AB357A-B8EE-49B1-A7C1-00F04CA027DE_zps
Started connecting up the power distribution box
24FF7B32-E10F-4C2C-8B90-74546FA741CC_zps
9C6B6713-D8CC-47B1-838A-A7A3F3E0BD79_zps
CC067657-FFFC-4F87-BABD-F5B770E9BA55_zps
More fun to come tomorrow 😊
