Anyone ever done this? Tips, Ideas, recommendations etc.
There are a set of shitroen wheels that I would like to put on a car with 4x100 PCD. Considering just welding a ring around the hole pattern to thicken it up and drilling the holes in the remaining space like a multi fitment alloy.
PCD adaptors would do the trick.
Wobbly bolts might do 98 > 100.
Other than that you could ask a decent machine shop.
Correcto 98-100 should work with wobble bolts
Red Drilling would both make the wheels look terrible and weaken them as they weren't dedigned to have 8 holes
Pcd adaptors all the way
It's a bit of a problem if it brings the wheels out as the wheels I were considering are already ET18. Also I don't want to sound pikey, but proper spacers are expensive! Drilling the wheel, adding more weld around the hole and then countersinking it is reasonably cheap if not completely free haha :p
Hmmm tbh redrilling or wobble bolts are just a faster way to die imo. Spacers/hub swap/ or different wheels would be my choices.
