akyakapotter Posted June 27, 2014 Posted June 27, 2014 (edited) As above anybody stuck one of these on stock internls getting bord of my power now and want a little more exctment. all the boys over the pond dont forge for td04 and run silly boost with no problems. Obviously I'll need bigger injectors I do have mls head gasket and arp head bolts just wanted people's thoughts on this thanks all Edited June 27, 2014 by akyakapotter Quote
akyakapotter Posted June 27, 2014 Author Posted June 27, 2014 Forge it and stop being gay? I don't want to lol I wanna be different Quote
Jim* Posted June 27, 2014 Posted June 27, 2014 I don't want to lol I wanna be differentWe've all blown out engine up mate there's nothing different about that Quote
Socks Posted June 27, 2014 Posted June 27, 2014 If it blows... Would you be happy to buy and replace an engine... if you don't think you would, stick with what you have! Raising boost over 1.2bar is pushing it ;) Tbh tho, billet wheel will allow you to run more power at the same boost anyway! Quote
akyakapotter Posted June 27, 2014 Author Posted June 27, 2014 I guess your right socks I want forge motor but suck at saving my money and the noise the billets make is amazing. think I'll have to start transferring money in to my other bank. Quote
amatthews45 Posted June 27, 2014 Posted June 27, 2014 At least get some gauges to monitor how much your pushing your engine Afr and oil pressure will allow you to see how much stress your putting on standard stuff. The right management is always a good idea you prob could push a little more boost with the ARP head bolts and gaskets but don't go silly. Quote
akyakapotter Posted June 27, 2014 Author Posted June 27, 2014 I have oil pressure anyway afr I used to have but was a shit Depo one management I already have emanage blue Quote
amatthews45 Posted June 27, 2014 Posted June 27, 2014 Get a good aft gauge and then ask your mapper to turn it up a little bit at a time I would suggest a good oil and more services if your going to push the block more Quote
akyakapotter Posted June 27, 2014 Author Posted June 27, 2014 (edited) Get a good aft gauge and then ask your mapper to turn it up a little bit at a time I would suggest a good oil and more services if your going to push the block moreI'll talk to Mike see if he tells me off for wanting to do it lol its a 236 mile drive to get my map tweeked lol Edited June 27, 2014 by akyakapotter Quote
daniel_g Posted June 27, 2014 Posted June 27, 2014 Go for it man, most people are to shitebag to push the standard lumps haha.Although for good reason, they are chocolate Its all in the map though. Quote
amatthews45 Posted June 27, 2014 Posted June 27, 2014 Daniel is right its all the map To much torque can push std right to the limits there are ways to push standard blocks without risking destroying it Quote
Jim* Posted June 27, 2014 Posted June 27, 2014 (edited) Best of luck to you, and keep in mind also that if the engine decided to let go it could also take out the turbo to leave you further out of pocket Edited June 27, 2014 by Jim* Quote
H_D Posted June 27, 2014 Posted June 27, 2014 Its the rods that will give up after 1.2+ bar of boost but should make good power safely at 1bar with a billet td04. Quote
akyakapotter Posted June 27, 2014 Author Posted June 27, 2014 So many mixed opinions that's what's I was looking for the good and the bad need to do something as 233.4hp just isn't cutting it any more Quote
amatthews45 Posted June 27, 2014 Posted June 27, 2014 Might want a reduced torque and more bhp map big torque will kill the rods. There are people that will able to push the car more for you on std rods and pistons. Quote
Ollieh17 Posted June 27, 2014 Posted June 27, 2014 Bit off topic, what is the accepted max torque figure for a standard 4efte then? Quote
