So mappings round the corner and i am aiming for 230bhp... Spec is
Zisco ramhorn manifold and down pipe to jperformance 2.5 exhaust heatwrapped
Tial external wastegate
Tf035 turbo
Standard engine
To fit:
emanage blue
TD Fuel pressure reg
Walbro fuel pump
Blitz ebc
I chose the tf035 over a td04 as it was never really my plan to map it. And prefered the quicker spool. Now im mapping im concerned it wont make the figures i wont. Am i wrong in thinking the 35 will make similar power as a 04 but cant run as much boost? Should i swap it out for a td04?
Edited by Ollieh17
Just go for it and see what you get, if it drives alright forget about the figure if its lower than you expected.
TD04s are good though thats why so many people run them, and no matter what anyone says they are not laggy in a well set up car :)
It drives pretty well atm on the standard ecu 0.7bar boost set on a manual boost controller. Fuells spot on on my aem wideband and pulls reall well. I just dont want to waste the mapping for a small end figure in a way
I've been running a tf035 at 0.9bar at 202hp at the flywheel for 2 years now no problem! :)
I used to run a td04 at 1bar at 220hp same engine
Is that mapped mate? Seems td04 makes more power then at similar boost levels? Cant see the tf making up the 18hp difference over an extra 0.1bar boost
They were both mapped at tuning developments
Mike said he was impressed with it and it wouldn't take much more to get close to that figure of the td04
also spools near 1000rpm quicker
Ollie it's not all about figures, having It mapped will make your driving experience better than not mapped, TF spools faster and TD spools slower so your on a winner with less spool just have slightly less power
I know which I'd prefere .... Less power better spool
Just my opinion but like dan said just go for it :D
James
Yeh man i know its not ALL about the figures, but everyone still loves them. For me its alot about the money .
I reckon it drives great atm just want a bit more. But if im Gonna spend £500 to get 10 or so hp doesnt seem worth it when i love the way it is already lol
If it's running as nice as you say, get on a rolling road and see what the output in its current form is and make a proper educated decision on ecu and mapping from there :) save some £££ then
James
James
This. I will be doing this when the my chasis is stiffer, gives something to aim for rather than numbers pulled out of the air
Plus you change your mind like the wind mate :p If you are thinking about cash it's probably costing you more switching parts than getting on with it and finding out where she is at now.
This is true, but the numbers are based on the large number of other starlets. I know i change loads haha,this is why i dont want to be disappointed when i map her. Already bought the fpr,ecu, ebc and fuel pump now lol. Ill get it rolling road and see what i think
What a lot of people forget is ..... Every engine is different
Two identical engines with identical mods being mapped and tuned by the Same person can sometimes have noticeable power differences, you could have good outcome or you could be disappointed :-/
I don't understand how this happens but it does haha
Deffo get it rolling roaded first :)
Yeh i know this man gonna get it rolling roaded. Thing with glanzas is they are light so hard to work out the power compared to other cars that have been roaded.
