Bean Posted June 29, 2014 Posted June 29, 2014 no one makes these, they would be a custom part. Quote
yaristurbo Posted June 29, 2014 Posted June 29, 2014 why has no one stripped one out and looked into this?? Quote
andros starlet Posted June 29, 2014 Author Posted June 29, 2014 i snap 4 shafts until now , dose any one know any shaft shop that can do custom !!! here in cyprus no one do this ! Quote
morgey Posted June 29, 2014 Posted June 29, 2014 Had a quick look on google.This popped up?http://www.reco-prop.co.ukOtherwise driveshaft shop in the U.S are renowned for there parts Quote
andros starlet Posted June 30, 2014 Author Posted June 30, 2014 i know driveshaft shop but like this custom work and import them in cyprus it will cost 2 times the price of the car Quote
andros starlet Posted June 30, 2014 Author Posted June 30, 2014 Had a quick look on google. This popped up? http://www.reco-prop.co.uk Otherwise driveshaft shop in the U.S are renowned for there partsthis reco prop looks good , i will contact them Quote
andros starlet Posted June 30, 2014 Author Posted June 30, 2014 It might be worth speaking to zisco about thisi think zisco was never did any 4wd one Quote
H_D Posted June 30, 2014 Posted June 30, 2014 Im sure they can make you one if you send yours off to them.best thing to do is drop Keith a PM.They would be my first point of call for any custom fabrication, Quote
andros starlet Posted July 10, 2014 Author Posted July 10, 2014 What are you doing that they are snapping?this http://youtu.be/5vfNrf7ZLmk Quote
morgey Posted July 10, 2014 Posted July 10, 2014 You removed the viscous coupling amd welded the diff? Quote
daniel_g Posted July 10, 2014 Posted July 10, 2014 Can you put a few pics up of it and a spec list please ?We all really wanna see it Quote
morgey Posted July 10, 2014 Posted July 10, 2014 you are a wizard Take that as a yes then.Been telling this lot to do that for ages but no1 has listened as far as I know. Haha Quote
morgey Posted July 10, 2014 Posted July 10, 2014 Use a image hosting site like photobucket. Then copy and paste the IMG code provided Quote
daniel_g Posted July 10, 2014 Posted July 10, 2014 Take that as a yes then.Been telling this lot to do that for ages but no1 has listened as far as I know. Haha When i break mine or blow it up or something then it'll get welded up haha. Quote
morgey Posted July 10, 2014 Posted July 10, 2014 Its the viscous coupling thats the main issue. It allows the power to get absorbed and not make it to the rear wheels. But id imagine if you did loose it and leave the rear diff open then you would just get one rear wheel spin, hence welding it which is suited more for drag racing. Quote
andros starlet Posted July 10, 2014 Author Posted July 10, 2014 Its the viscous coupling thats the main issue. It allows the power to get absorbed and not make it to the rear wheels. But id imagine if you did loose it and leave the rear diff open then you would just get one rear wheel spin, hence welding it which is suited more for drag racing.and once again you are a wizard :)i need maximum traction but i snap the shafts Quote
