id like to know this as well as Im running one on my forged build going in for an EMB and map soon be nice to know what people can push these to
What you currently running at ?
have no idea as I haven't had the car on a dyno since ive had it, its running a jam ecu but im having knock sensor issues until I get my new engine loom in once that's in il be going for a map
I have a speed vison hybrid ct9 atm.still in the process of setting up fully in conjunction with a external wastegate etc etc.
I would expect they would make around 230 at 1.2 bar on a good day.
I agree 230 on that boost in my opinion they work better 1.1 very max because of the heat 0.9 boost spring pushing 1.1 through a decent ebc for quicker spooling :)
On the leaderboard the most powerful ct9 hybrid is 254.5bhp at 17psi no build thread though and don't know what hybrid it is
Must be forged, for one run I suppose you could put the boost up bit constantly running that would probably be risky for the turbo all the time especially winter time.
yea it was forged, ill be aiming for the same figure and mines a second car so wont be coming out in shite weather
Might aswell go td04 if your forged 280 bhp ebc lighter flywheel and a top notch clutch :)
Tbf neither are really easier. Td04 just provide that guaranteed power. And are cheaper to replace and buy in the first place. Not many people make over 220 on a hybrid
yea but a lot of people make over 220 on a td04, its easier to make that power. Im just going to push the ct9 as far as possible and see if I can break the 250
ct9s and ct9 hybrids get to hot and have to be pushed to the limit to get good power out of them and not good for your engine, You will better off with something a bit bigger making more power at lower boost.
The less boost that goes through the engine the less it gets stressed.
personally I would look at the new billet td04s which are making near enough 300bhp at 1bar - baby boost but big power
I would say 260 is more than enough for the weight of these cars I wouldn't like to be pushing more than that around a corner fwd but if I was forging mine I would go td04 route you will get the most out of your engine/cash that way but then again less lag is the key for me.
