  • Replies 152
It's not really that bad, unless the car looks shit, like mine at the moment with the wrap peeling off... They actually need 3 reasons to give a Yellow. First time I got one, the guy was inventing reasons to have my Starlet inspected. He doubted my red lug nuts and pointed out that I didn't have rear seat headrests...
  • 4 weeks later...
After waiting for a while to get some parts I bought from UK, I can finally make some progress. I'm getting the car ready for paint meaning removing the wrap and, now that my stuff arrived, installing my plate surround. I'm also deleting the locks on the boot and passenger door.
10734080_10204225045138124_8229700518651
10458662_10204225046258152_1014974404739
Not sure yet how I'll feel this weekend, body or engine work?
Lol Yeah, but if it looks like shit the cops will pull me over for yet another yellow sticker because they think it will fall apart...
My last canari inspector said to make it look clean to not attract attention, and my tuner said to make it look so boring the cops wont even think that the engine is modifed...
Thanks for the comments.^^^ Some progress today, in 2 steps.
This morning I showed up at work once again while the shop is closed...
10712696_10204241154620851_3814078766796
1920234_10204241155220866_82983302450317
10347698_10204241155940884_7008423395950
67216_10204241156780905_8675219341537494
10171091_10204241157540924_2085970557039
10703810_10204241157300918_6550474281533
1229819_10204241157620926_32651073796021
10672236_10204241158140939_7281413748943
And when the salesmen left, I went back home and...
1925309_10204241159100963_83600463175594
10702230_10204241159300968_7102195542580
10710877_10204241158940959_1876931291874
As you can guess, I had to stop because of weather, but not the rain, it would have been alright under the carport if it hasn't been for the bloody wind... Let's hope it's better tomorrow.
Thanks mate!
Got a bit of a problem now. I had all my parts under my bench at work, but I was moved to another bay last month. moved some stuff, left some, all ID'd. 1st of this month, a Wednesday night, I replaced the clutch of my second Starlet with the donor Paseo one. The 5E flywheel didn't fit the 4E, but clutch and PP went in. Now I'm closing in on the swap, but I cannot find the freakin' 5E flywheel anywhere!! I had it in my hands 4 weeks ago... I hope the guy that cleaned up before getting fired didn't throw it out.... :(
Not the same car, but...
This is my other EP91. Bought it cheap, body is in bad condition, but I don't care too much about that. But it always overheated, since I bought a month ago...
10421472_10204331676843850_3981254261048
So I brought the car back from a mates place last Wednesday, and this happened:
1013516_10204331676763848_40365629000451
I got around to fix it Yesterday, I used my old Paseo rad I had lying around and decided to change the thermostat to the Paseo's as well, it wouldn't hurt... Well I found this:
10417519_10204331676683846_1298189215837
It's no longer overheating... :yahoo: I didn't find the rest of the stat, but I think it rusted out, desintegrated, and got stuck in the rad... the inside of the hoses were the same color as the stat, so is the inside of the expension tank.
The Paseo rad kinda fits, lower mounts are at the same distance from each other, so are the outlets, but they're a bit offset. I had to relocate the tank to the passenger side and turn its bracket around to make it fit.
  • 1 month later...
Ok it's been a while since I updated. Sorry 'bout that, I've been busy, changed jobs, been to Canada, etc.
Now I'm back on it. I have a few done since last time, I left you with my valves and shims.
I set the clearances, Installed the cams and the cambelt. Also the coolant and thermostat housing.
10665346_10204378689219130_2319050729452
10365907_10204378689259131_5707265992471
On the car, I installed more of Jezza's goodies, bonnet lifts are up and running, I also did the front Park lights mods.
10730960_10204378692379209_5194783776210
247171_10204378692419210_426039601163814
10439031_10204574286588942_7499178198965
I started my brakes conversion with the Paseo rear axle I had collecting dust and wasting space.
10696220_10204378690699167_2633450743799
11371_10204378690819170_4101983039666561
10603516_10204378691059176_7124527485250
Followed a few weeks later by the front end...
10169261_10204555917889736_8896998170317
10393852_10204599402816832_1034808902307
10858391_10204599404536875_2629918438738
I removed some unwanted weight
1533736_10204561214782155_20446030023607
10393174_10204561217382220_2602314095204
Back on the engine, the inlet has been powder coated, installed with the inlet spacer, bits and pieces coming in to complete the engine, water pump, dizzy cap & rotor, leads and plugs, the rear of the engine is about done by now.
10367593_10204574286908950_8277634062802
10511137_10204594694259121_7178210002729
10847830_10204599405496899_7686010130333
1555275_10204622866483409_41490518381270
I found what must be the last available 5E flywheel in WA after mine vanished...
10846062_10204599402136815_2628051396257
I fitted the Paseo's shifter, travel is slightly shorter, but not enough to be noticeable. Also installed a safety feature...
10347168_10204628722669810_2181076288209
10384295_10204628724789863_2534449977369
That all folks! Stay tuned for more updates, the old engine is coming out of the car next week :D
10393592_10204599406376921_8656868335494
Edited by FMuscle
That stats not disintegrated the bottom halfs been cut off just leaving the ring in there to act as a seal as without it it would leak. Person you bought it from has prolly cut it to try and stop it over heating... I.e. He probably gathered the stat was sticking/not opening.
I doubt the previous owner did anything to it... mid 20's girly girl learning to drive RHD... The tabs did look broken and corroded, not cut, and something was blocking the flow in the rad... Anyways it's now fixed and it's just a beater anyway. The good one will be back on the road shortly.
