Glanzacoley Posted September 1, 2014 Posted September 1, 2014 Right I want to run a screamer pipe on my ep82 with it coming out of the bonnet what would I have to have for this? Also what does externally waste hatted mean, what would I have to change? Quote
Gainzy Posted September 1, 2014 Posted September 1, 2014 Contact Wepr on here in the traders section they will know! Quote
yaristurbo Posted September 2, 2014 Posted September 2, 2014 Means your turbo is controlled by a waste gate on the Manifold, no longer by the little penny inside the turbo Quote
Beastmode panda Posted September 2, 2014 Posted September 2, 2014 Right Also what does externally waste hatted mean I'm glad you asked this. The answer to that is basically a hat, any kind of hat you wish actually. You put it over your wastegate (otherwise known as 'hatted') and it keeps it warm, mainly for in the winter time so the little fella doesn't get chilly. It's beautifully simple - Here's an example. Quote
TrisK Posted September 2, 2014 Posted September 2, 2014 I'm glad you asked this. The answer to that is basically a hat, any kind of hat you wish actually. You put it over your wastegate (otherwise known as 'hatted') and it keeps it warm, mainly for in the winter time so the little fella doesn't get chilly.It's beautifully simple - Here's an example.I have heard that being wastehattde could seriously conceal boost spikes. Ie the boost spike could be under the hat. Or even worse poke through the hat if it's a particularly sharp oneDo you have any advice for this Quote
Beastmode panda Posted September 2, 2014 Posted September 2, 2014 I have heard that being wastehattde could seriously conceal boost spikes. Ie the boost spike could be under the hat. Or even worse poke through the hat if it's a particularly sharp one Do you have any advice for this Hello TrisK, i think you might mean 'hatted'. When the boost spikes, usually the hat has a built in sensor from 'factory'. IF (and god forbid) you did suffer from hat spike the police would be rung automatically (via said sensor). Unfortunately this means you'd have to exit the vehicle literally no matter what. Anyway, that is the general gist of things. When your get your hat you should have got a bookbiblething, in which you need to read - William IIV Chapter 27 verse 101 for a more in-depth explanation. Quote
Matt1878 Posted September 2, 2014 Posted September 2, 2014 I'm glad you asked this. The answer to that is basically a hat, any kind of hat you wish actually. You put it over your wastegate (otherwise known as 'hatted') and it keeps it warm, mainly for in the winter time so the little fella doesn't get chilly.It's beautifully simple - Here's an example.F'ing brilliant.. I have no words. I was looking at going down the route of external wastegate but I'm not sure of the pro's and cons of going externally hatted? Quote
Beastmode panda Posted September 2, 2014 Posted September 2, 2014 F'ing brilliant.. I have no words. I was looking at going down the route of external wastegate but I'm not sure of the pro's and cons of going externally hatted? There are no cons. And there is one pro; God created hats. God is not a con-man. Just remember that. Quote
mikey4410 Posted September 2, 2014 Posted September 2, 2014 Hats of to them, they make good picture explanation. But seriously.....go external, boost is regulated sooo well , as good as 0.02 accuracy. Mine hits 1.02 bar in every gear in any situation.so accurate. Boost creeps for losers.......haha Quote
Ollieh17 Posted September 2, 2014 Posted September 2, 2014 Waiting for half of UKSO to come on and kill the joke now ;) Quote
Ethanep82 Posted September 2, 2014 Posted September 2, 2014 Does anyone have a picture of a internal waste hatt?? Quote
Djaniero Posted September 3, 2014 Posted September 3, 2014 I'm glad you asked this. The answer to that is basically a hat, any kind of hat you wish actually. You put it over your wastegate (otherwise known as 'hatted') and it keeps it warm, mainly for in the winter time so the little fella doesn't get chilly.It's beautifully simple - Here's an example. Rob you fckin funniiiiiiiiiiiiiii guy. . You kill me at times I swear!!! Quote
