  • Replies 463
  • Created
  • Last Reply
Top Posters In This Topic
Great news charlie i may see if im about and will meet you there. Ive just spoken to Rob a couple of minutes ago and he mentioned your going down
Ok buddy :)
  • 2 weeks later...
Little update!
Still no engine, it's all built and ready for me to collect we are just waiting on a crank pulley to turn up! This should turn up at Robs tomorrow and I'll go down after work to collect the engine :)
Meanwhile I sent off my cam cover to Dean @ RW Developments to be acid dipped and sprayed gloss black.
Posted Image
I have also purchased a few other bits so will update when they arrive :)
Just reading your whole build.
Mate your a trooper! much respect!
There is allways light at the end of the tunnel  :thumbsup:
Thanks buddy! Love the car too much to give up!
Always nice seeing a fresh engine. Glad you have got it back. Enjoy and take your time getting everything else 100% :) look forward to updates
Yes. cant wait to see this built again
Me too!
Yes yes. Ill try and pop over sunday if you need a hand..
If your about mate! Could do with putting that fuse back in!
Test fitted the manifold and turbo this evening just to make sure the turbo wasn't fouling on anything!
Also added a little strip of heat tape to my fresh cam cover!
And this turned up from Idrees yesterday! Thanks bud!
Rear entry front mount, should help with spooling times slightly!
Edited by Charlie28
Great update matey cant wait to see in the bay. Somthing im looking to do is back door intercooler set up.
If I had the time and money, I would of just taken the car down to Dean @ RW! As you fully well know he is the man for this kind of thing!
Yes mate he is the man im in chats with him for some modifications to my set up. Like i said tuned in to your build
Another update!
A while ago I purchased some levin brakes and disc's from Russ on here, but after fitting them found that my Rota's where hitting the callipers. I kept my eyes open for a pair of hubcentric spacers to pop up for sale and with a bit of luck some 20mm ones came up so I grabbed them.
Got these fitted and then found that the wheel studs extended through the spacer and wouldn't allow the wheel to sit flush! So today I enlisted the help of my old man to cut the wheel studs down for me!
Once we had done both sides I chucked on a wheel and checked clearances! All was good!
Problem solved! Now I just need some for the rear!
Also some bits turned up for the engine from TD! Thanks Mike!
Edited by Charlie28
  • 3 weeks later...
Im so glad you persisted with this! Wat a weapon it will be!
Looking good mate, get it back in the car and get some boost running thru it :D
Cheers lads, got a few things to tiny up the engine once its in!
