Hi guys, I have a genuine lsd box in my glanza v, basically it wines when driving, luckily I know the previous owner and he told me that the gearbox was run without enough oil. Gearbox still goes in and out of gear smooth, and drives lovely, would I be right in saying lsd bearings? And if so anyone changed them? Or have a guide on changing them?
Thanks! :)
Does yours whine worse on acceleration? Mine isn't too bad when your coasting but on acceleration it's bloody noisy lol
Thanks for reply!
Kyle.
So on closer inspection today I don't think it is my lsd, I'm thinking it's the input drive bearing, still not 100% sure,
When coasting with clutch pressed, no noise, clutch out noise, I don't think it's a clutch bearing, purely based on the fact it's too noisy!
Anyone got any ideas?
Cheers, kyle!
Colin, have you tried changing your clutch release bearing at all? Spoke to a friend of mine last night, he said he's had release bearings that have been noisy, and if it was his car he would try the release bearing first!
Cheers, kyle.
My corollas box sounds like a straight cut gearbox when you get into 4th and 5th. Pretty sure its the diff bearings as i can move the inner cv cups up and down if i lay under the car and wriggle them Lol
I'll have to try and wiggle my drive shafts to see if it's them,
Is a c56-02b a common box?
Anyone know where I could get a rebuild kit? I've found a couple but there 600 usd just for the bearings!
Mines been whining since april/may and I've been trying to break it but it just wont haha
Take the drain plug out and you might be able to break it lol :p
Im guna sit about reverse to 1sting it before it comes off the road. I already flat foot shift with it and slam it through the gears with no care :lol:
