Need help getting my glanza through mot, Anyone got any ideas why It has failed on emissions Its got a CAT on :/
Edited by Glanza1996
Ask for a copy of the 4 gas readout.
Did you take it a good run before it was tested ? And is the CAT in good visual condition ?
Excessive CO is normally suggests running rich AFRs.
The major exhaust leak at the front certainly wont be helping though.
Id set the ignition timing, set the fueling if you can, or if its mapped then just leave it as it is.
just find a cat friendly place dude.had decatted cars for 5 years and the bloke I see never has an issue with it.
Thats alot easier said than done. Did you take it for a good blast before the mot. Also have the definetly tested the car has a glanza? 4efte only have to pass a basic emmisions test i believe.
Well it goes down as a non CAT test if the tester puts in 4EFTE but the limits are the same as a CAT test if its after July '95 iirc
It all depends on when its registered really.
Edited by daniel_g
Na I didint take it for a run as I was at work when it got tested I dropped it off in the morning, I've got a zisco manifold on that wouldn't have any effect would it? The cat visual looked fine when I put it back on but I will pop it back off on the weekend and double check as I have git 10days to sort it.
that probly be it they tested on a cold engine the cat will be stone cold and not reacting chemically
Yeah thats what I thought I will upload the emissions test sheet inabit.
Looks like its been done right with the correct settings.
Fix the exhaust leak, set the fuel pressure to stock if you can and set ignition timing.
Take the car out for a good run before you take it in, get the CAT cooking lol.
You got bigger injectors in it ?
No I dont have bigger injectors I will give it a go at giving the car a good blast, Does anyone know were I can buy a offside front anti-roll bar linkage ball joint dust cover? got any links Thanks.
