  • Replies 140
  • Created
  • Last Reply
Top Posters In This Topic
Progress has slowed due to the lads doing my wheels taking all the time in the world ha did get custom catch tank and coolant tank
7B825034-1FB1-4B1A-8BE3-C43FF6B1D58A_zps
9711DEF2-1899-4D8A-8BAA-F0568441FE3B_zps
7AE6758C-B142-402A-BB9D-5F78F37DC1CC_zps
4D8CF889-73BD-4EB1-9EC3-0D28F771291F_zps
27638B85-6CAC-4099-B995-1307402FE150_zps
  • 5 months later...
  • 4 weeks later...
  • 3 weeks later...
so small update have been doing abit of hoarding and polishing ha bits are gathering up nicely picked up a ct9 and mani off jap91 just want to get the car running to work out any flaws in the system also picked up rear calipers have cleaned them and painted them black and bought rear dimpled and grooved discs.. front mount intercooler bought polished core and piping as i like my shiny bits same with a half rad i bought ,,, got a cusco panhard rod came sandblasted and powdercoated courtesy of christyep91 also bought the 4pot wilwood set up ebc pads and braided linesoff him a trd front anti roll bar and rear reflect lights never realised how beautiful a light they are ha (pity my paint looks ridicolous in the dark :silent: :silent: )picked up a race spec rocker that is in the process of been polished as pics will show yous have a racing developments catch tank on the way and bought blue silicone hose kit of tuning developments to replace most pipes in the bay and a few more bits like seals and a sard fpr whiteline rear arb nearly new and painted blue as i always do
have picked up body parts but thats been kept under wraps to keep ye guessing ha
slowly coming back to life
Got my water/oil pipes from tuning very impressed seem top quality... Rw developments catch tank landed gave it a quick polish also got new injector seals and made up brackets to mount my intercooler, cleaned an primed the trd front anti roll bar to ... Good evenings work ha ive probably made more progress in the last few weeks then i did in the entire attempt at first build on this car also have picked up oils and coolant
getting there ha
99% of pipework fitted checked and tightened just need a quick double check
changed oil filter and filled with oil
drained gearbox oil and filled with new oil
clutch is ready to bleed
powersteering is just waiting to find a custom s/s bottle hopefully
just waiting on unf 12.9 grade bolts for my wilwoods on route from england
just need to fit rear brake set up also
all suspension needs tightening and fitting of arbs
waiting on coolant temp sensor then can fill radiator
picked up new rocker cover seal and spark plug seals from toyota
short route hot pipe is on route and new polybush front arb bushes also
wiring needs a bit of tidying up sensors connected up etc hope to get that done the weekend and a bit of tidying on pipework like catch tank etc but as far as i can see all i am left to buy is magnecore leads and we should be looking at turning the key in her ha :D :cheers: :cheers:
really need to get a shiny wepr manifold kit in her , wont be long :roll:
did get a little side tracked bought myself a zep dash pod for my gauges mainly cause i hate seen wires running around the dash
anyone got a link to wiring the starter? dont want to mix up wires but id imagine all the connectors are different sizes so can only take correct wire but just incase
also anyone with a powersteering bottle and nut and bolt off the top hole of the starter where it mounts to the gearbox get in touch with me ha
also can i run without a dumpvalve?
few pics as always
Car coming along nicely crying out for a manifold tho. Yes you can run with out a dump valve
definitely getting one just want to get it up an running first work out any flaws that i may or may not have
no oil leaks as of yet which is good :cheers:
filled coolant/water and of course one pipe was missed ha so once the water leak in the most awkward spot on the engine stopped i tightened up the clip and perfect no leaks
few more bits on the way hopefully have them before the weekend but all is looking good for waking this lady from her sleep before the christmas
also had a nice job of getting the temp sensor out that i rung off flush in the thermostat housing :pirat:
removed charcoal canister just need to replumb venting and pointless bulkhead sensors removed
IMAG0215_zpsxa9uei1i.jpg the culprit :evil:
Rear caliper carriers fitted and rear id workz discs bearings cleaned checked and greased also painted the front hub caps black to blend in with the wheels
Got my Cusco pan hard rod greased up and fitted along with white line rear arb
Slowly but surely becoming road worthy IMAG0226_zpseek5vsjl.jpgIMAG0223_zpstuquxqhe.jpgIMAG0222_zpswmupnqe4.jpgIMAG0219_zpsnntncwsk.jpgIMAG0218_zpsnr8syq4b.jpg
