amatthews45 Posted December 12, 2014 Posted December 12, 2014 Hey everyone. Now I am keeping myself busy restoring the starlet and the more I strip the more problems i find. Took both door cards off today to see if I can get the motors off to sort them. Couldnt Get them out just yet but will keep trying. Both the door cards were wet on the bottom and my passenger door has a little water in the bottom of it. Could some point me in places to look? Also got a leak from boot it seems to come from the top near the spoiler run down the chassis behind the lights and to the bung under the light that's broken. I have bodged that to stop leaking but need perm solutions for my leaks please. Cheers Quote
JamesD89 Posted December 12, 2014 Posted December 12, 2014 Have you got the plastic see-through stuff behind the door card? i ripped mine out changing the window motor and it has leaked in since making the door card wet. . Quote
amatthews45 Posted December 12, 2014 Author Posted December 12, 2014 Had plastic on the driver side but not passenger side. Driver side was wet though just not as bad as passenger one Quote
fiddlersport Posted December 12, 2014 Posted December 12, 2014 two rubber o rings and a bit of silicone sealent for the rear light fix, Tailgate rubber boot for wire also requires refitting and a bit of sealent Quote
mikey4410 Posted December 12, 2014 Posted December 12, 2014 Yeah a good permanent fix is a good quality black sealant round all bungs and fittings that seal against water.just had all this leak business wih mine.was an old bung not sealing to well anymore and sealnt has sorted it out beautifully. Quote
amatthews45 Posted December 12, 2014 Author Posted December 12, 2014 Where's the drain hole you speak off fiddlersport? I was just gonna try get a new bung thing that the light sits it. Tailgate rubber boot wire? You reckon that would be on of my leaks? Any suggestions on what sealant I need? Wanna make it look at neat as I can ideally Quote
fiddlersport Posted December 12, 2014 Posted December 12, 2014 Hello rear lights hole, easy fix, sealant or buy the genuine plastic thing tailgate-towords the top right of the tailgate is the tailgate wires which run through the rubber, this has probably come off, clean up and reattach and use some silicone sealant and let it set. check your rear washer wiper pipe, the one that joins the roof to the tailgate (pipe) your windows misted up all the time ? spray some water over the tailgate and get a friend to jump in the boot ! listen for the water drops doors and sills, there are drian holes on the tailgate and doors and sills, they probably need cleaning, if water does come in then it can run out Quote
fiddlersport Posted December 12, 2014 Posted December 12, 2014 >https://www.youtube.com/watch?v=UPgF4YAHBQY Quote
amatthews45 Posted December 12, 2014 Author Posted December 12, 2014 Yeah windows always misted. Can't believe how much water comes out that vid gonna try find my drain holes tommorow they easy to spot? I know where the water travels from boot it goes between the gap between chassis and spoiler and runs down the left side towards the light then goes under the light but then into the car because the plastic bung don't work :/ Quote
fiddlersport Posted December 12, 2014 Posted December 12, 2014 your boot carpet sponge will probably be wet and may be your carpet, take them out and dry them, next fix them leaks and you should be fine. hated it when my car was steamed up and now the problem is fixed its so much better Quote
fiddlersport Posted December 12, 2014 Posted December 12, 2014 a few drain holes on the actual sill, few drain holes on the bottom of the door, tailgate, bonnet. Also check your rubber grommits, may just require a clean and refit Quote
amatthews45 Posted December 13, 2014 Author Posted December 13, 2014 The carpet in boot not wet I have put temp things to soak up any water. Will attack the drain holes asap really need to get to the bottom of it all really Thanks for all the advice and such anything else I should check? Quote
fiddlersport Posted December 13, 2014 Posted December 13, 2014 clean all the rubber seals and the mating surface, i used the halfords silicone rubber spray for window seals, door seals.... was on the motorway last night and less cabin noise and no water leaks, (really bad rain) the reason i was fixing all the leaks so i can now use the jute felt behind the panels for insulation and sound deadining while your door cards are off if you fixing the door leak you might aswell use some sound proofing Quote
Calum122 Posted December 13, 2014 Posted December 13, 2014 Serious common problem on them mazdas Quote
amatthews45 Posted December 13, 2014 Author Posted December 13, 2014 Don't really wish to add weight like sound proofing. I might get some stuff to add the plastic back on door card. Will find the silicone rubber spray cheers. Not had chance to do anything today but will go round the whole car tommorow. Any tips for loose door seal? As I was messing yesterday I loosened the seal on the passenger door. Quote
daniel_g Posted December 13, 2014 Posted December 13, 2014 Its normal to have a bit of water is your doors, well not hundreds just a few drops running down the window and stuff. You just need to get a sheet of plastic and make sure the door is 100% sealed and the cabin doesnt get damp. Clear the drainholes out on the bottoms of the doors.As for the door seal which runs round the door, there are small slits in it for clips about every foot or so, they can be a bit tricky to get back in. Quote
amatthews45 Posted December 14, 2014 Author Posted December 14, 2014 Right with everyones help all drain holes are good and clear. Stil l have water going from the gap in chassis and spoiler going down the passenger side to behind the light will try find a new bung for under the light unit and see if that fixes it. Will find some plastic to seal the doors once I have new window motors Quote
