Dear RACETECH/ DTA users
It's not that expensive Phil. Fire blades use the same coil packs which are cheaper then a trigger wheel and crank sensor easy got just need someone to machine the pilot and make a bracket
if there was something ready to go off the shelf - coil packs, rocker cover setup trigger wheel and bracket etc etc id be considering it
sounds like nasty work.
Phil
  • 3 weeks later...
  • 1 month later...
as an update it turns out the guy just got fed up and decided to fold the company however a deal has been agreed to pass the company to another person who is in the process of taking over as we speak. so should be back to normal soon. the new owner was prevoisly working on a andriod app so its looking like support for this will be a certaintity which should be nice for my tablet install :p
