how much for these posted mate?
sorry i meant the wings
Would do them both £60 plus postage, I can either stick them on a pallet or just cardboard wrap them and let you arrange postage - then you have the option for insurance etc
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 weeks later...
Are the Powerflex Poly Rear Axle Bushes sold?
Yup, sold.
Does this still have a rear standard tow bracket / mount and is it removable? I'm pretty sure my Glanzas is missing
It does and it is. I actually removed a while ago to paint and sheared one of the bolts so it never went back on. So you might want to check the bolts holes on yours first. if you do want it you can have it for a fiver plus postage.
Also I'm away with work again at the moment so won't be able to post anything soon.
Yup, sold.
Did the door cards go matey?
What's left??
The list of mods is above and still have some standard parts, easier to ask what you want...
Just woundering do you have or selling indiglo dials ?
I did have but they're sold.
Rear bumper price if you still have it cheers?
Sold already.
are the wishbone front bushes there
also i need the ecu plugs
They're still in the wishbones, was going to try and get them out at some point (without damaging them), they're super pro ones. Athough do the older GT's use the same size as a glanza? Similarly are the ecu plugs the same?
yes plugs same , but V has a 3rd plug that i need also the 12 pin ( with wire on ) i need them to go in a glanza ecu !!!
if them bushes are 34mm they will fit also they come out very easy put a big bolt on the bush sleeve then you can push the sleeve out and the insert out to :)
