jayc-glanza17 Posted March 22, 2015 Posted March 22, 2015 Took sump off today, needs resealing.I found these however.. Pics belowI have checked the conrod for play..Their is none front to back, and only a milimetre side to side if that.So pretty much as engine was 5 years ago.Engine didn't knock when ran for 10 minute plus on Friday at my tuners whilst sorting out a sensor problem on ecu. Quote
morgey Posted March 22, 2015 Posted March 22, 2015 Locating lug around the oil drain on the inside of the sump? Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Could be haven't checked that.. Quote
morgey Posted March 22, 2015 Posted March 22, 2015 Have a gander im sure I've seen this before and thats what it was. Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Thanks matey.. is it on sump or block? Quote
morgey Posted March 22, 2015 Posted March 22, 2015 On the inside of the sump where the oil drain from the turbo comes back in. I think its from that. Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Cheers buddy, I look at that when I'm back home. Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Just to add. Oil pick up has no metal particles at all. Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 (edited) Here's some extra pics of the pieces together. Edited March 22, 2015 by jayc-glanza17 Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Coin is a 5p coin in last picture Quote
mikey4410 Posted March 22, 2015 Posted March 22, 2015 man thats crazy.silly question but is that metal or rubber ?pretty mad dude Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 It's metal and magnetic.I'm thinking a captive washer but from what.. Quote
daniel_g Posted March 22, 2015 Posted March 22, 2015 (edited) Looks kinda like where a valve spring would sit in.but too small Edited March 22, 2015 by daniel_g Quote
maddox710 Posted March 22, 2015 Posted March 22, 2015 Its not what the pick up pipe pushes into is it? Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Good point will..Something to check when I finish early Tuesday. Quote
maddox710 Posted March 22, 2015 Posted March 22, 2015 Its been a while since I've had engine on stand it's about right diameter Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 I'm racking my brains trying to remember, the parts it could be.It appears so far everything's fine.As ran for 15 min plus Friday and no knocking noises.. Quote
Rob H@RCH Engineering Posted March 22, 2015 Posted March 22, 2015 That looks like it could be a thrust washer from the turbo, as it seems to be a machined part. I'm Only looking at it on my phone tho Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 My old td05 was bad wen we took it off..So very possible rob. Quote
Rob H@RCH Engineering Posted March 22, 2015 Posted March 22, 2015 Broken up that small it would easily get down the oil return pipe into the sump, so thats what I would say it was then. There's nothing els in the engine that small it could be really. Quote
jayc-glanza17 Posted March 22, 2015 Author Posted March 22, 2015 Thank you rob..Been researching and looks like a washer ihi use..It's so small can't think of it being engine part. Quote
Liam_D Posted March 22, 2015 Posted March 22, 2015 Was going to say it looked like a thrust washer from inside a turbo. Quote
maddox710 Posted March 22, 2015 Posted March 22, 2015 Yea could be my td05 shit itself i could also have this in my sumo haha Quote
