well as some of you may know i had a 206 gti6 showcar with around 30k spent on it, and just got my new car today in a px deal the car is ofcourse a glanza.
Spec:
.Greddy TD04-11g Turbo Kit (Down pipe, Stock manifold adaptor, Brand new Braided Oil Line)
.Dave Burwash Manifold
.Powerflow 2" Turbo Back System
.Front Mount intercooler
.Sard rrfpr
.Speedvision 330cc injectors
.Walbro Fuel Pump
.Zep Racing 1.2mm Headgasket
.Greddy Type-S Bov
.Autofixed FMIC
.HKS FCD
.Exedy Organic Clutch
.Koni Ajusterble Shocks (40mm Springs)
.Earls Braided Lines (Blue, Never Used)
.3G Grooved & Dimpled Disc's
.Stock Rear Disc's + Bearings
.Anti-Lift plates
.Clear indicator Lenses
.Carbon Fibre Bonnet (Toyota Stamped)
.Bonnet Pins
.Front + Rear Splitters
.Advanti Ultra Light wheels
.Toyo 888 Tyres front
.Bridgestone potenzas Tyres back
.Autometers Boost gauge
.Nomanracing Pillar Pods
.TRD Lether Gear Knob
.Din Tray with door
.Pioneeer CD Player
.Pioneer Front Speakers
also the car has had a rebuild with 4x new pistons + Rings, 4 x Conrod Shells. Head was skimmed and fully serviced with new valve stem seals, new Battery, Distributor cap + Arm all new gaskets.
Brand new Exedy clutch
nice mate, that is minted, the owner before obviusly knew what he was doing,
whats your current plans for this and how are you finding the power?
the powers different on boost the glanza is very quick, the 206 had power all round in any gear
going to need to get used to the clutch though
im going to get an alarm and a turbo timer first before any major plans occur.
lol not good, the perks of having a modified car!
whats wrong with it like?
That is a nice glanza it was si_glanza's over on tgtt. He certainly didn't do it right the first time by whacking a hybrid on with out checking the fuelling hence the rebuild.
I'd get some decent management like an emanage and set it up on the rollers, it will prob produce a bit more power and you'll know it will definately be reliable then.
Good luck with it.:p
@59bhp Its just running a sard rrfpr and hks fcd.
Nice buy!
Seen this in the flesh and is definitely one of my favourites Glanzas! (It was partly my inspirtation too)
Bought it off a top bloke too :p
Good luck with it
  • 1 month later...
  • 2 weeks later...
what the tdo4 11g?
i will take some pictures when i get the car back, the turbos brilliant though a little bit bigger than a ct9 and hardly any lag at all in comparrison with other tdo4's
yeah, the turbo.
heres some pics of my kit. im 99% sure you have it now... i can find any pics of the downpipe, but heres the turbo and the little adapter thing.
also, you want me to change the title of this topic? its a bit indecisive.
yeah, the turbo.
yeah you can do if you like, like i said as soon as i get the car back ill take some snappys, looks pritty much the same though, if you sold it to si_glanza on tgtt then it will definatly be it.
any opinion on this turbo rick?
