glentwenty Posted May 11, 2015 Posted May 11, 2015 Hey people bit of a starlet noob as you can probably tell, I really want to get my starlet to get 0-100 in high 9s at the least, does anyone know what parts to look for? I know everyone says to get the rolla intake but I'm sure my starlet already has on unless the rolla looks the same but is bigger, any info would be awesome will make a build thread if I do it Quote
5e colin Posted May 11, 2015 Posted May 11, 2015 what car have you ??? 4efte starlets are faster then that in stock form Quote
adzy Posted May 11, 2015 Posted May 11, 2015 what car have you ??? 4efte starlets are faster then that in stock formLooks to be posted in the n/a section so a 4efe I'd say Quote
5e colin Posted May 11, 2015 Posted May 11, 2015 jeeeeeeeeez didnt spot that so back to the op you can change to rolla tubular intake mani and a 4efte TB exhaust wise fit a 4efte 1 with a custom up pipe rip the head of and start port matching then a rev upgrade !!!!!! fit 4efte loom ecu and dizzy coil setup ( yes it will fuel fine in na form ) lightweight pully set and a 4efte light flywheel :) there is plenty more you can do but how deeeeep are your pockets ???? Quote
FrozenJakalope Posted May 11, 2015 Posted May 11, 2015 20v 20v all the things!That's your solution for everything! Quote
jimmymac101 Posted May 11, 2015 Posted May 11, 2015 That's your solution for everything!And for very good reason ;) James Quote
FrozenJakalope Posted May 11, 2015 Posted May 11, 2015 If I had a 4age lying around, I'd do the same in a second Quote
morgey Posted May 11, 2015 Posted May 11, 2015 Pop over to ireland. Can get a running levin for 1200 notes ;) Quote
glentwenty Posted May 11, 2015 Author Posted May 11, 2015 jeeeeeeeeez didnt spot that so back to the op you can change to rolla tubular intake mani and a 4efte TB exhaust wise fit a 4efte 1 with a custom up pipe rip the head of and start port matching then a rev upgrade !!!!!! fit 4efte loom ecu and dizzy coil setup ( yes it will fuel fine in na form ) lightweight pully set and a 4efte light flywheel :) there is plenty more you can do but how deeeeep are your pockets ????Thanks for the info man. Pockets aren't too deep but will see what I can do I may already have rolla intake, from photos I've seen mines the same unless the rollas is bigger Quote
daniel_g Posted May 11, 2015 Posted May 11, 2015 If yous is the gen3 4EFE then they are pretty slow in stock form, think they have some kind of economy map with a lean burn.Best bet is try get a hold of a Gen1 4EFE ECU. Quote
glentwenty Posted May 11, 2015 Author Posted May 11, 2015 What would be better gen1 4efe ECU or 4efte ECU?? Quote
glentwenty Posted May 11, 2015 Author Posted May 11, 2015 I'll upload a photo later of my engine bay so you can see what gen motor it is Quote
glentwenty Posted May 12, 2015 Author Posted May 12, 2015 Sorry about quality my iphone 6 got fried so using a 38$ android haha This is my engine <3 anyone know what gen it is? is that the rolla manifold or not? Manifold!Throttle body! Quote
daniel_g Posted May 12, 2015 Posted May 12, 2015 What would be better gen1 4efe ECU or 4efte ECU??A Gen1 4EFE ECU.And yes thats the corolla tubular inlet you have. Quote
glentwenty Posted May 12, 2015 Author Posted May 12, 2015 A Gen1 4EFE ECU.And yes thats the corolla tubular inlet you have.Really? Cause i bought this car off an old guy and i cant imagine why he would have put a rolla inlet on the car. Does that give any indication to what motor this is? I didnt know the starlet motors came with the rolla inlet Quote
glentwenty Posted May 12, 2015 Author Posted May 12, 2015 Wait that photo answers my question! The gen 2 has the rolla inlet on it so mine must be a gen 2 no? Quote
morgey Posted May 12, 2015 Posted May 12, 2015 The gen2 jdm engines had the cat just under the manifold iirc. If its not there and is under the car its prob a uk engine with a rolla mani fitted. what car is it youve got? Quote
glentwenty Posted May 12, 2015 Author Posted May 12, 2015 (edited) The gen2 jdm engines had the cat just under the manifold iirc. If its not there and is under the car its prob a uk engine with a rolla mani fitted.what car is it youve got?Its under the car, I have a ep91 reflet f. Idk why it has rolla mani unless someone put it on there before i got itI just looked my car up on CARJAM and it is a JAP import so it cant be a UK motor can it? im so confused hahaha Also standard Green injectors if that helps Just had a look under the hood to check colour Edited May 12, 2015 by glentwenty Quote
morgey Posted May 12, 2015 Posted May 12, 2015 I might be wrong about the cat then it might be the gen 3 that have it in the downpipe.Yours is most likely the gen2 then since its a reflet which is an import. Quote
glentwenty Posted May 12, 2015 Author Posted May 12, 2015 Hmm yeah maybe! So if i already have rolla inlet that rules that out. Gotta get my hand on a gen1 ecu then and exhaust manifold Dunno where im gunna find one of those ecus over here.. not much Starlet hype over here haha Quote
nitrosmith0815 Posted May 12, 2015 Posted May 12, 2015 Why breaks the torque down at the gen1 engine? Is there something which switch on/off? I didnt see this 100hp engine bevor...but it is very interesting! Quote
nitrosmith0815 Posted May 12, 2015 Posted May 12, 2015 If one had a second gen1 ecu - i would like to have one... Quote
glentwenty Posted May 12, 2015 Author Posted May 12, 2015 Why breaks the torque down at the gen1 engine?Is there something which switch on/off?I didnt see this 100hp engine bevor...but it is very interesting!The gen2 ecu had slight adjustments from the gen 1 ecu to reduce exhaust emissions Quote
