EP82 Nearly Dies When Electrics In Use
So when in my brothers car we notice the idle drop significantly when the alternator is under load. Now it does this in my car, but not to the extent that it does in my brothers.
It will idle spot on at 1000 rpm, turn everything on, heaters on full, lights, dipped and fogs. Then the idle drops to around 400-600 rpm, amazing it doesn't stall.
Naturally he is trying to avoid this at the moment. But was just wondering if anyone else has incurred anything similar.
When the engine is cold and I have the headlights on etc, most of the time the car does a cold high idle of ~1000-1500 (which is normal?), and then some days it'll be a pain in the arse and idle at 600rpm no matter what, shaking the car to bits. Does my tits in, but the grey unit on the end of the inlet mani (ICV?) was a new item about 2 years ago, so can't be that. I'm wondering if it's throttle body related, or grounds related...
