Countryman Posted June 23, 2015 Posted June 23, 2015 Can anyone help me My warning light has stopped working I've checked the bulb and it's fine and fuel gauge works properly What else could be causing the light not to come on when low on fuel?All suggestions appreciated Quote
ChrisssAhhh Posted June 23, 2015 Posted June 23, 2015 There is a sender unit in your fuel tank that could be the issue. Quote
Gainzy Posted June 24, 2015 Posted June 24, 2015 Think most people's tend to pack in, pretty sure mine doesn't work neither I never let mine get under a quarter anyways so I wouldn't see it ha! Quote
Dale SR Posted June 24, 2015 Posted June 24, 2015 Ye mines has went on a couple of my Starlets I've just done what Gainzy dose Quote
kbond Posted June 24, 2015 Posted June 24, 2015 Mines the other way around the light is always on haha Quote
Gainzy Posted June 24, 2015 Posted June 24, 2015 Mines the other way around the light is always on hahaDrive me crazy that would lol Quote
Countryman Posted June 24, 2015 Author Posted June 24, 2015 It does not bother me as I've been driving for over 6 months since it stopped working but I just like things to work, I know I'm being a bit obsessive but that's me. I was told a while back that's it good to let the tank get low so there is less crap deposited at the bottom of the tank, don't know how true that is but it's become a habit now. Thanks 👍🏻 Quote
5e colin Posted June 24, 2015 Posted June 24, 2015 mine stopped working to and i only get it to work disconnecting a wire on the pump !!!!! i gave up on trying to get it working Quote
Starlet__SR Posted June 24, 2015 Posted June 24, 2015 Had the same issue on my Cynos. Ran it down as far as I dared, and do you know what happened? Yep, ran out of fuel haha. Day Quote
Dan507 Posted June 24, 2015 Posted June 24, 2015 mine use to work intill i ran it out of fuel one time, then it never worked after that lol Quote
Countryman Posted June 24, 2015 Author Posted June 24, 2015 Where is the fuel sender unit located and would I need to replace the whole thing or can I fix the faulty bit that's causing the light not to work? Quote
ChrisssAhhh Posted June 24, 2015 Posted June 24, 2015 The sender is in the tank attached to the float on the pump, best to replace it all Quote
FrozenJakalope Posted June 25, 2015 Posted June 25, 2015 I didn't even know starlets had a fuel warning light hahahaha Quote
aleximport25 Posted July 22, 2015 Posted July 22, 2015 My light worked when I got mine but then it came in constant even with a full tank then it went out for good. But the mrs's sr works perfect Quote
