I am looking to map the car for 1.2bar on td04 so am looking for 460cc injectors that are direct fit keeping in mind I may go for more boost in the future what are the options of direct fit injectors available as I see they can be very pricey
You had me thinking for a min lol 2.5 bar boost through a 4e crazy lol
Cheers matey I need them pretty fast from America they would take a while do you know any direct replacement from another car I heard evo 4/5 are
Im using the tuning developments 430cc injectors and using these to go 300+hp so around 1.4bar so I would say 430 would be fine!
Rx8 injectors are pretty much the same! :)
ive used a few sets of rx7 ones there a direct fit. 1.2bar your stock injectors wouldnt even be maxed so dont really need changed to be honest
So the mazda rx7 injectors don't require anything else just take out stock put in bigger injectors no need for resistor box ect
Stock injectors are maxed out around 1.1/1.2 bar depending on condition and that was on a td04 setup. Thats all i could take mine to when it was on the rollers getting setup ... Thats was with a standard fpr aswell ! I wouldnt imagine they would have lasted long been maxed out like lol
I ran my stock injectors and stock for at 1.3bar on a td04 for well over a year and a half with no bother at all till I broke the car. Was a low milage engine to start with tho
Rx8 injectors definitely a direct fit mate?
They plug straight into the your original loom but you will require an aftermarket ecu to run them! Be sure to get second hand ones flow tested etc or just by them from tuning developments? They are on there website! :)
  • 3 weeks later...
