uprated injector options
I am looking to map the car for 1.2bar on td04 so am looking for 460cc injectors that are direct fit keeping in mind I may go for more boost in the future what are the options of direct fit injectors available as I see they can be very pricey
Stock injectors are maxed out around 1.1/1.2 bar depending on condition and that was on a td04 setup. Thats all i could take mine to when it was on the rollers getting setup ... Thats was with a standard fpr aswell ! I wouldnt imagine they would have lasted long been maxed out like lol
  On 7/3/2015 at 7:09 PM, ashep91 said:
Rx8 injectors definitely a direct fit mate?
They plug straight into the your original loom but you will require an aftermarket ecu to run them! Be sure to get second hand ones flow tested etc or just by them from tuning developments? They are on there website! :)
  • 3 weeks later...
