i know lads its a joke, i even heard a women in the shop saying she 's going to report me to the police little did she know i was standing behind her.
would having the wrong plugs in be interfering with the tv's, and im not running cb or scanner.
You go to the police first, report that you are getting stick from your neighbours about the apparent problem. There is no way your car is causing a problem
Check what the plugs are first, I ran some Vpower plugs in mine and they caused no end of issues with signals to the ECU as they where non suppressed plugs and I was told they can cause the same problem with TV signals too! Old school copper core plug leads used to do the same thing too but I very much doubt you will have them lol
Try changing the plug leads, or maybe it is the exhaust doing it? Have got got a cat to test fit see if that helps?
Cars do have a interference suppressor in the loom somewhere but thats for the cars electronics, not surrounding houses far as i know.
Some old mopeds do exactly the same. It's from the coil/ht leads. Either update the leads, give the coil a decent earth or check for arcing at night with the engine running. You may see tracking on the outside of the ht leads causing the interference.
