glanza ep91 23 Posted August 2, 2015 Share Posted August 2, 2015 I have a 5e which I'll be forging and I also want to build the head aswell And I'm not sure what high lift cams to get Quote Link to post Share on other sites
AdamB Posted August 2, 2015 Share Posted August 2, 2015 What's the rest of the spec? Turbo, ecu, engine components, compression etc etc. Best answer is leave the OEM ones, their fine as they are for a turbo motor, could go with some slightly more lift but other than that leave as is. Turbo engines don't like wild cams, especially small engines with no compression to get them working. Quote Link to post Share on other sites
glanza ep91 23 Posted August 3, 2015 Author Share Posted August 3, 2015 Basically I want the works,I plan to fully forge the engine (8:1 comp)and plan on running a Garrett gt28 , not sure on ecu yet The head seems to be a black art so I want to get the best for the car Thanks Quote Link to post Share on other sites
maddox710 Posted August 3, 2015 Share Posted August 3, 2015 Just leave cams stock and puts some fresh springs in it Quote Link to post Share on other sites
AdamB Posted August 3, 2015 Share Posted August 3, 2015 (edited) Basically I want the works,I plan to fully forge the engine (8:1 comp)and plan on running a Garrett gt28 , not sure on ecu yetThe head seems to be a black art so I want to get the best for the carThanks Stick to stock cams, the reason why these cylinder heads seem to be a black art is because they work well from standard trim.What are you going to use the car for? If you got money to waste then go and stick a set of cams in, but I can assure you that'll you get sick of having no low-mid range power at all, and that won't be helped by such low compression and a large frame turbo Ganing 10-15whp up top Vs driveability and response is what it comes down to. Edited August 3, 2015 by AdamB Quote Link to post Share on other sites
Socks Posted August 3, 2015 Share Posted August 3, 2015 My old setup was a....4E-FTE GTX2863R @ 2.2bar.... Over 400bhp EASY... Stock Cams Waste of time and money thatr could be spent improving other things on the setup... Quote Link to post Share on other sites
glanza ep91 23 Posted August 3, 2015 Author Share Posted August 3, 2015 What about standered but higher lift Quote Link to post Share on other sites
AdamB Posted August 3, 2015 Share Posted August 3, 2015 (edited) Go ahead, they'll be a custom set. There's more to cams that just the duration and lift. What about the LCA, ramp rate, then getting a spring and retainer to suit, the list goes on and on. Either forget about it, or pay someone with a lot of knowledge and experience as well as a lot of money to get you a worked cylinder head. Edited August 3, 2015 by AdamB Quote Link to post Share on other sites
glanza ep91 23 Posted August 3, 2015 Author Share Posted August 3, 2015 It's looking that way I'll definitely get a professional to build the head I just want to find out who's the best around and what I have to look out for (a lot of idiots around who think they know it all I just want to know what I'm on about so I don't get fooled) thanks for all your help Quote Link to post Share on other sites
Matt1878 Posted August 3, 2015 Share Posted August 3, 2015 Starlet cams are more than capable mate.. No need to go custom, waste of money if you ask me on these cars.Matt. Quote Link to post Share on other sites
AdamB Posted August 3, 2015 Share Posted August 3, 2015 (edited) 99% of the so called "professionals" don't even know what their on about when it comes to cylinder heads and cam selection, that includes some of the starlet tuning "guru's". This is why cylinder head work is such a black art, it takes many iterations of cylinder head port design and component selection to get the right one, and even then it isn't gonig to be right for everyone. If you want to speak to people about cylinder heads, speak to those that design and manufacture cams, Ivan Tighe, Kelford to name a few, they will recommend a cam and the required valvetrain needed as well as things like the base spring pressure, opening and closing degree setc. Take it from me, no more than 240 duration and approx 8.6mm lift intake and slightly more 8.8-9mm on the exhaust (unless you go for bigger valves). Don't stray too far from the stock LSA either. Edited August 3, 2015 by AdamB Quote Link to post Share on other sites
Phil Posted August 3, 2015 Share Posted August 3, 2015 (edited) we only have two head gurus in N.Ireland (interested in turbo stuff - though lots of n/a rally guys in the south) even the big tuning companies take your ££$$ an sub it to the same guys. (steven gault and ivor greenwood) mind you ivor has had a 5e over 600 hp on sunoco so very real gains exist. Phil Edited August 3, 2015 by Phil Quote Link to post Share on other sites
glanza ep91 23 Posted August 3, 2015 Author Share Posted August 3, 2015 (edited) Thanks very much Edited August 3, 2015 by glanza ep91 23 Quote Link to post Share on other sites
animal GT Posted August 3, 2015 Share Posted August 3, 2015 Over 600 Phil. ? Who is this guy Quote Link to post Share on other sites
sbk replica Posted August 4, 2015 Share Posted August 4, 2015 now cams are the subject here, is there any diffrence in cams between te 4E and 4EFTE ? Quote Link to post Share on other sites
turbo Grant Posted August 4, 2015 Share Posted August 4, 2015 I like my cam's in my daily. Go for it pal! Quote Link to post Share on other sites
LukeH Posted August 4, 2015 Share Posted August 4, 2015 Inlet cam on 4efe is different. Quote Link to post Share on other sites
Phil Posted August 4, 2015 Share Posted August 4, 2015 Over 600 Phil. ? Who is this guyI'd guess it was Ecc Think Ivor does their headsPhil Quote Link to post Share on other sites
animal GT Posted December 24, 2015 Share Posted December 24, 2015 Phil who is this ivor guy? Quote Link to post Share on other sites
adzy Posted December 24, 2015 Share Posted December 24, 2015 Phil who is this ivor guy?Ivor greenwoodhttp://www.greenwoodengines.com/services.html Quote Link to post Share on other sites
animal GT Posted December 25, 2015 Share Posted December 25, 2015 Cool never heard of him and he has a starlet himself is it. Might give him a shout Quote Link to post Share on other sites
Phil Posted December 25, 2015 Share Posted December 25, 2015 Cool never heard of him and he has a starlet himself is it. Might give him a shoutNo starlet Sean. But nice fella, give him a ring after Christmas, won't talk to a nicer fellaPhil Quote Link to post Share on other sites
starletezy Posted January 6, 2016 Share Posted January 6, 2016 Not worth spending money on high lift cams stocks cams are more than capable of make very good power Quote Link to post Share on other sites
Phil Posted January 6, 2016 Share Posted January 6, 2016 Not worth spending money on high lift cams stocks cams are more than capable of make very good power kinda right yeah. but all this blanket advice is no help to the guys needing cams lol Phil Quote Link to post Share on other sites
