Is it possible?? (window hindge conversion)
its possible but it wont look like on a gtt you will have to bond a rubber to the chassi where the current window glue is right now the windows will be stikking out a tat
use the 2 hinges and lock from the gtt the hard part will be drilling and making the mounting points welding on a bracket for the nuts etc etc
glass can be drilled d.i.y. to
