What discs are those?? :o light have found some 406 calipers for cheap, there's heaps of peugs in Fra'ce at least :D need to know!! :)
Edited by EP70-PT
  • Replies 114
  • Created
  • Last Reply
Top Posters In This Topic
These discs from G60 corrado. 280mm. Biggest discs that I found with 4x100 PCD. It would be better use bigger discs and redrill to 4x100.
Cage is really nice - is it a custom one or a kit?
Thank you. it's FIA homologated 253.8.3.1 roll cage setup.
Bodywork looks good. Genuine items or id-workz?
Interested in the brake setup too. Have you had custom brackets made to mount the brembo ?
It's id-workz. Yes, I made custom brakets, used 10mm steel.
  • 4 weeks later...
  • 3 weeks later...
What gauges are you using mate awesome build
Thank you. There are Depo gauges.
Edited by Anglas
