5efhe NA oil feed to turbo options??
Re-tap for a 4efte oil filter housing, or the easy option is t-piece the oil pressure sensor in the block and take a feed off there. You can do the same for the water lines under the throttle body too, saves having to swap the thermo housing aswell.
dont have to the center bolt is good enough to seal it
but you could tap the 3 small 1s if you want , i didnt on my 5e and hasnt leaked in 5 years
exact same...hasn't leaked in 8 years....just clean both surfaces properly, apply some engine silicone to the respective areas and secure with the centre bolt to the correct torque specs
