Starletson
    86
1 Follower
    Bristol
1924 profile views
Starletson's Achievements
  1. What would be the pros/cons plus parts required to turbo the 4e versus chucking a 5e in her? Does the 5e just need the engine and a 5e engine management and bobs your uncle?
  2. She looks sad 😊 Finally got a passenger door! Just need to fit it ðŸĪĢ que wonky door ðŸĪŠ Been in for new discs and pads and had rear bearings done. In for MOT on 2nd Sept ðŸĪžðŸŧ
  3. Might have to go k20 route, apparently there is a drop in kit available for it now?
  4. 👌ðŸŧ😎
  5. Didn't get the bits in the end, weather was shite and flooded roads etc. Getting her MOT'd soon. Can anyone confirm if I need Glanza calipers to upgrade the front brakes? Or just the pad carriers?
  6. Off to Devon this weekend to get some doors and a v boot lid with v wang 👍ðŸŧ
  7. Hi, made an order about 2 years ago, not received anything Order 6168, club decals and lanyard Thanks
  8. Any admin?
  9. Any admin can help? This is ridiculous
  10. Nice 👍😎
  11. Order 6168, club decals and lanyard
  12. Hi, made an order a long time ago, not be received, been told to contact one of you guys, cheers
  13. My mechanic put it on. As far as I'm aware it went straight on. I wasn't there when he installed it
  14. Probably need to sort out the paintwork, the passenger door is getting bad on the bottom corner and the rest of the car is in need of some tlc. Rear drums and front calipers could do with a lick of paint, so could some engine bay brackets. Glanza front brakes would be a nice addition, may just upgrade these original discs and pads when the time comes. Rear wheel bearings need doing and the rear shocks may need replacing Got some 303 to spray on the rubbers Need to clean the grime off the side of engine as I'm getting some belt slippage and the annoying sqweek I've replaced all the headlight bulbs with some phillips ultra white aswell May take a wire wheel to the rocker cover and see how that turns out
