dan106
    1421
Everything posted by dan106
  1. Fresh import? Sent from my iPhone using Tapatalk
  2. Ooo what you got rob? Yeah it's one thing after another with it atm, probably gonna need a rebuild soon too lol Sent from my iPhone using Tapatalk
  3. You got another starlet rob? It's broken half the time these days Sam aha, needs a clutch before I can drive it properly again atm Sent from my iPhone using Tapatalk
  4. Na me and Dave have gts, a couple of na's/ glanza reps there is a glanza but it's not on the road yet aha Sent from my iPhone using Tapatalk
  5. I'll probably be there in my daily, unless I get a clutch in my gt by then Sent from my iPhone using Tapatalk
  6. Still up for coming Milton Keynes to meet up dude? I'm sure all us guys would love posh photos of our cars aha Sent from my iPhone using Tapatalk
  7. dan106
    Ac radiator ep82
    I've got one but it's also old and been sitting outside for a while so I'm not sure of the condition Sent from my iPhone using Tapatalk
  8. I'd have to have a look, where'd you end up sourcing the bigger master cylinder from? Sent from my iPhone using Tapatalk
  9. Think I'll give that a go see if it helps, is this a common thing with twinpots? It feels like my girlfriends saxo when one of her rear shoes weren't attached lol Sent from my iPhone using Tapatalk
  10. Is there anyway to adjust the pedal so it bites earlier? All round the brakes three times now, with Toyota dot 5 Sent from my iPhone using Tapatalk
  11. Na both bleed nipples are at the top of the calipers aha, I have taken it for a proper drive and re bled them, can't drive it too hard atm the clutch is roasted Sent from my iPhone using Tapatalk
  12. I fitted twin pots on my gt a few weeks ago, bled them up twice already, but the pedal still feels like there's air in the system, and there's a lot of travel till the brakes engage fully Anyone else experienced this?
  13. You got an up to date link for the xtd Colin? And do you use a normal release bearing or one that comes with the kit?
  14. I thought it was, you should come when we do a mini meet in mk man Sent from my iPhone using Tapatalk
  15. Well it's basically a civic underneath, but it isn't jap lol has advans on it though lool Sent from my iPhone using Tapatalk
  16. I'm not sure how it would make a difference but I'd definitely re bleed them with it off just to be sure, hoping this will fix mine aswell lol
  17. Will it matter if my starlet doesn't make it and I come in my daily?
  18. Did you have the handbrake on when you bled them? I did when I changed front calipers and I have a soft pedal now, haven't managed to fix it yet mind
  19. Ah that's a result then, already got box oil for my new gearbox then lol
  20. i have read the oem lsd doesn't need lsd specific oil, is it true?
  21. I might give that a go when I stick new cables in, the gear change has always been a bit shit on mind so it might've happened either way
  22. Not sure if this is because of the short shifter but i reckon it is, definitely does put strain on the cable. When this happened I was literally just put the car in reverse
  23. One of mine has snapped, for an ep82 but I assume glanza ones are the same?
  24. Went past you on the a5 just up from junction 9, was in my rover lol
