Ep91 kid Posted April 1, 2016 Posted April 1, 2016 Right, got a td04 kit on the way but I'm hearing mixed views on converting the internally gated td04 to external. I understand the way to do this is by welding the stock wastegate shut but I don't really like the sound of that. Is there another way of doing it and if not has anyone experienced any problems with this method? Any help appreciated Quote
Sefton-EP91 Posted April 1, 2016 Posted April 1, 2016 It's your best bet to be honest mate, welding the wastegate closed.I remember reading somewhere that you can make a bracket to hold the wastegate closed. I think it was Dean at RW Developments that's made a braket. Hope this helps! Quote
daniel_g Posted April 1, 2016 Posted April 1, 2016 Theres no issue with welding the penny shut, i personally wouldnt trust a flimsy bracket to hold it shut, theres a chance it wouldnt hold properly and youd get a leak. Quote
ChrisLeeBoost Posted April 1, 2016 Posted April 1, 2016 Unless you ever plan on going back internally gated ( you won't go back ) then weld it shut mate. Quote
Maxep Posted April 1, 2016 Posted April 1, 2016 Instead of welding the flap closed, you could always weld the actuator arm in the closed position instead. This way you can probably go back to internal if you decide . Quote
starletezy Posted April 1, 2016 Posted April 1, 2016 welding the actuator arm shut is another good option Quote
adzy Posted April 1, 2016 Posted April 1, 2016 I made a bracket and used a threaded bar to hold mine shut (ct9) it's held firmly closed and there is no movement in the bracket. Gives you the option of you ever need to go back to internally gated, not that I plan to tbh! Quote
Maxep Posted April 1, 2016 Posted April 1, 2016 You will never go back, especially with a screamer haha. Quote
Gainzy Posted April 1, 2016 Posted April 1, 2016 You will like the sound of that off full boost! Get it welded up ewg is the way forwards Quote
daniel_g Posted April 1, 2016 Posted April 1, 2016 Screamer life consists of being out terrorising the community, deafening children, causing havoc and getting asbos Quote
mikey4410 Posted April 1, 2016 Posted April 1, 2016 Screamers are awesome.they sound great.I welded the actuator arm to the sleeve it moves in.never had an issue. Quote
aleximport25 Posted April 1, 2016 Posted April 1, 2016 Mine was welded at the actuator arm when I bought it and not had and issues :-) Quote
Ep91 kid Posted April 1, 2016 Author Posted April 1, 2016 My only worrry with welding the penny shut is isn't the exhaust housing cast? I always thought welding cast was frowned upon? Quote
RobSR Posted April 1, 2016 Posted April 1, 2016 ^ no it's fine. You just need someone who knows what they are doing lol. Quote
olidaviesuk Posted April 10, 2016 Posted April 10, 2016 spot weld the arm, had no probs with mine and six months use Quote
