Id go with the Draper 2 tonne Low Profile Trolley Jack with Quick Lift iddy brought one myself not so long ago great bit of kit
Makes lifting the car easier about 3 pumps and its up in the air mate
Drive on wheel chocks, just little ramps that give you that extra height.
That's what I do thick square blocks and a normal jack still won't fit under and I'm on 16's I need to make bigger chocks :(
I have had the Clarke 1.5 tonne jack for over a year now and it's possibly the best jack I have owned. It is really only a shop jack though as it's very low to the ground. I would definitely go with the Clarke jack
I did come across SGS Engineering but I've never heard of the brand before so I was unsure. I like their 2.5 tonne jack so that now leaves me with 3 options.
Thanks for your input guys. I need to make my mind up and order something in the morning!
I had a clarke aluminium race jack. They are absolute poo! First time I jacked my starlet the seals went. Got it repaired and it lasted a while but the bolts always came lose. The seals went again and I got it repaired under warrenty just after making a fuss. Then the seals went again shortly after. Go to you local snap on man and buy the blue point low entry one they are about 140 I think. An awesome quality jack which will last year's. They are very well built to last in a garage. A clarke aluminium one wouldn't last 5 minutes. I couldn't trust another one of those.
