bajansuperman Posted November 14, 2016 Posted November 14, 2016 Hi, just wondering if anyone have ever try fit any other suspension on the starlet? Sent from my SGH-M919 using Tapatalk Quote
bajansuperman Posted November 15, 2016 Author Posted November 15, 2016 Vw polo 6n2 I have in my StarletNice did u document it and is there a linkSent from my SGH-M919 using Tapatalk Quote
SpikeyJp_68 Posted November 16, 2016 Posted November 16, 2016 (edited) It's on tggt.com I think Edited November 16, 2016 by SpikeyJp_68 Quote
5e colin Posted November 16, 2016 Posted November 16, 2016 It is yes and toyotaownersclubirl to my pics are gone from my thread on err mustn't anew laptop before I can amend it as fones areuseless Quote
5e colin Posted November 17, 2016 Posted November 17, 2016 http://www.ukstarletowners.com/topic/58164-coilover-question/ Quote
bajansuperman Posted November 18, 2016 Author Posted November 18, 2016 Nice project but I wanted to know about getting rid of the back beam completely Sent from my SGH-M919 using Tapatalk Quote
gorganl2000 Posted November 18, 2016 Posted November 18, 2016 that's going to be a lot of custom work and parts....the cost may make this prohibitive for the benefit you will get from itfor the average joe, it may be better to spend less money on coilovers, tires, bushings, arb, braces, etc. Quote
5e colin Posted November 18, 2016 Posted November 18, 2016 Nice project but I wanted to know about getting rid of the back beam completelySent from my SGH-M919 using TapatalkE10 corolla rear independent setup then bit of cut and weld no personal experience with that setup just got the info of the lads of tocirl Quote
Phil Posted November 18, 2016 Posted November 18, 2016 one option id considered was a 4 link system fabricated to fit with a very basic rear axle setup. by the time you do all the fabricating as cheaply as possible and source the necessary parts (brakes etc) to make it work, 1k minimum more like 1.5k 2k would be comfortable. Phil Quote
bajansuperman Posted November 18, 2016 Author Posted November 18, 2016 (edited) that's going to be a lot of custom work and parts....the cost may make this prohibitive for the benefit you will get from it for the average joe, it may be better to spend less money on coilovers, tires, bushings, arb, braces, etc. Seems that way was trying to see what ideas people had as I was planning to build this car for just track days consulted apart of Neils team and he said its all time patience and headaces his was fitted with puma s1600 rear Sent from my SGH-M919 using Tapatalk Edited November 18, 2016 by bajansuperman Quote
bajansuperman Posted November 18, 2016 Author Posted November 18, 2016 one option id considered was a 4 link system fabricated to fit with a very basic rear axle setup. by the time you do all the fabricating as cheaply as possible and source the necessary parts (brakes etc) to make it work,  1k minimum more like 1.5k 2k would be comfortable.   PhilThanks philSent from my SGH-M919 using Tapatalk Quote
gorganl2000 Posted November 19, 2016 Posted November 19, 2016 (edited) Seems that way was trying to see what ideas people had as I was planning to build this car for just track days consulted apart of Neils team and he said its all time patience and headaces his was fitted with puma s1600 rear Sent from my SGH-M919 using Tapatalk and as you know here in Barbados, getting the parts and the custom work will seriously drive the price up...and actually neil's starlet was the first that came to mind which is some serious engineering and fabrication work that is going to run you some major $$$ even for a far more simple set up i'm not sure if you can take the rear floor pan and gas tank off an ep85 and transfer it to the ep82??...at least that would give you a base for independent suspension, but then again the costs involved...just using some basic calculations i'd say you looking at BDS$5,000/10,000 plus depending on what you want to do, who does the fabrication, importing items, etc...........BUT if one is going to go through all that trouble, then it would make sense to try to adapt a better rear suspension set up from maybe a honda or some other model???!!! that's why i suggested the coil-overs, braces, struts, roll bars, tires, etc....may land you at the lower cost point and give you much needed improvements with minimal downtime PS--just for the UK users the currency conversion is about gbp1 = BDS$2.55 Edited November 19, 2016 by gorganl2000 Quote
Bluebear Posted November 20, 2016 Posted November 20, 2016 RobSR had an IRS setup using bits from various Corollas and Levins but he never used it before selling. Quote
gorganl2000 Posted November 20, 2016 Posted November 20, 2016 RobSR had an IRS setup using bits from various Corollas and Levins but he never used it before selling. the ae100/ae110 rear suspension set up actually crossed my mind too....but still a fair bit of effort and cost i just dont see an "easy" way to achieve it....that's why i think most people have just upgraded the stock set up over the years and with decent results too a proper fabricated independent rear set up would be cool though Quote
bajansuperman Posted November 25, 2016 Author Posted November 25, 2016  the ae100/ae110 rear suspension set up actually crossed my mind too....but still a fair bit of effort and costi just dont see an "easy" way to achieve it....that's why i think most people have just upgraded the stock set up over the years and with decent results too a proper fabricated independent rear set up would be cool though  That's the idea I had but money wise your right, but if I had the tools I would attempt it with guidanceSent from my SGH-M919 using Tapatalk Quote
morgey Posted November 26, 2016 Posted November 26, 2016 Its not just fabbing it up its getting all the roll centers and other stuff correct. If you didnt care much for all that, mounting it all up wouldnt be that bad if you could weld, id just buy the rear subframe frame any ae92/101/111 that might need narrowing to align with the eps rear chassis rails then wang that together with the car, that then gives you your hubs and 6 arms mounted to your car. The arms can either be made adjustable (2 are stock for rear tow) or shortened/lengthened to suit then a bush made up to fit in the eps swing arm mount for the trailing rod. Then just a case of cutting the top mounts out and welding rolla ones in. At the right height obviously. Then just brake lines and handbrake cables.Easy peasy 😂 Quote
azerty Posted December 15, 2016 Posted December 15, 2016 (edited) Neils team and he said its all time patience and headaces his was fitted with puma s1600 rear That's actually a precious info that I've never been able to get from Neil's team. I will be working on the rear beam next year. But for now, we only plan to enlarge original one and add vitz RS hub/brake system. changing to independent would probably better. But if not good, it will be a pain to find why ! Edited December 15, 2016 by azerty Quote
gorganl2000 Posted December 15, 2016 Posted December 15, 2016 lionel, as said earlier, the amount of custom fabrication and work that went into neil's car, it may simply not be worth the cost/effort for you in your class,, and i'm sure getting the building details would be even more stressful as the group tries to protect its competitive advantage locally----that car falls into a fiercely competitive rally group where stage times are seperated by tenths/hundredths of a second usually between the top 3 carsyour idea sounds reasonable as the stock rear brakes are a total waste, so any improvement should net you some returns Quote
5e colin Posted December 15, 2016 Posted December 15, 2016 (edited) lololol...totally agreed this topic has come up quite a few times over the year...apart from neil and some rear or twin engine set-up (i think richard posted pics some time ago), i can't recall many others trying it bimotoman did this on his twin engined starlet leave the engine out and it can still be used with blanking cvs richardC what you think Edited December 15, 2016 by 5e colin Quote
gorganl2000 Posted December 16, 2016 Posted December 16, 2016 bimotoman did this on his twin engined starlet leave the engine out and it can still be used with blanking cvs richardC what you think some secrecy about that set up too?? Quote
5e colin Posted December 16, 2016 Posted December 16, 2016 some secrecy about that set up too?? nope w3as nothing secret about it he showed al over on toc.irl Quote
gorganl2000 Posted December 19, 2016 Posted December 19, 2016 nope w3as nothing secret about it he showed al over on toc.irl you have a link?...i'm not familiar with that site Quote
roachburger Posted January 7, 2017 Posted January 7, 2017 one option id considered was a 4 link system fabricated to fit with a very basic rear axle setup. by the time you do all the fabricating as cheaply as possible and source the necessary parts (brakes etc) to make it work, 1k minimum more like 1.5k 2k would be comfortable. Philwill it be any benefit over standard ? 4 link would still retain the fixed rear axle wouldn't it ? Quote
