Is it worth the time porting the stock CT9 wastegate as i will getting an electronic boost controller soon and i want to prevent as much creep as possible, Please let me know your experience and opinions as i am changing my manifold tomorrow so i could do it at the same time while the turbo is off the mani.
Thanks josh
You'll still get boost creep, it'll help matters but not by much. Are you still running the standard manifold too?
I wont be from tomorrow ill be running a toyo sports one, I know there not the best manis and not even close but thats my budget at the moment will be upgrading to wepr in a matter of months. Thanks josh
Better than the standard though, the port restrictions on 2&3 are an issue.
Yeah thats one of the main reason for the change! I will be updating my progress log a huge update to come not updated it in months will post my spec soon.
if you port it enough should solve boost creep. Mine did. Shut the penny and mark around the outside. Then port as close to the line as you can i left about a 1mm
Will get on it then, Any recommendations on the best bit to use on the dremmel?
  • 5 years later...
@Sam44 @Claymore
Hi. I would like to know if I will be able to lower the 2&3 custom exhaust mani restrictions without ruining it. The restrictions are the stud bumps that shouldn't be lowered.
