Rotating td04 method?
Have seen 2 different ways 1 being completely separating the core and the other being just rotating the compressor housing (looks a lot easier if u have the pliers) but will the oil return and water etc be in the right place? Think this method may just be for other cars? Cheers
Its mega easy mate, get your self some circlip pliers, get the circlip off, then you will need to file/dremel down a small metal pin in the compressor housing you cant miss it, then you can rotate it freely, if your turbo has only just come off a subaru you will also need to remove the exhaust housing and rotate the centre cartridge to make sure the oil return is facing the floor. and put it all back together!
That pin pulls out with pliers. :)
Cheers nick :)
Sweet thanks so I do need to keep trying to separate them with a rubber mallet lol any other ideas other than wd40 and rubber mallet seems to be on pretty tight has been left for 2 nights as well?
Heat gun usually works need to get it really hot though!
Cheers nick :)
Even better!
Yeah mate the circlip part looks easy enough just having trouble separating to spin the oil return round some people said use heat I have a butane torch how would i use this to help separate, just heat the exhaust housing side?
  On 7/26/2017 at 2:33 PM, Ollieh17 said:
to rotate the exhaust housing there is a metal collar around the core you have to undo that
Yeah have removed that but really doesn't want to separate!
  On 7/26/2017 at 2:40 PM, Ollieh17 said:
hit it harder
Lol it's already took countless swings with a rubber mallet hasnt moved 1 bit don't really wanna use proper hammer on it unless it's only option
  On 7/26/2017 at 3:56 PM, Ollieh17 said:
take it you are hitting the flange to try get it to spin round? rather than hit them apart
Yea mate trying to get it to spin (although tried both ways) just been out having another go still doesn't wanna budge at all havnt tried butane torch yet
