Sign in to follow this
stevie82
Short route hot pipe
Does anybody know of anywhere that sells short route hot pipes new ? For ct9
Share this post
The only one I've seen is the JPerformance one but they don't seem to have the best reputation for sending orders out of late.
Looks like the HDi intercooler kit uses a short hot pipe route. You used to be able to buy just the pipework, might be worth asking HDi. Try and buy the hot pipe as a spare part?
Pretty sure any of the fabricators (Wepr, Race tech, TD etc.) could make one, not a particularly hard design. Custom one off so may cost a bit.
Or another thought, haven't played with a CT9 but if you can clock the compressor housing so the outlet faces down you could end up with an even shorter route. Would still need a custom pipe (2 bolt flange with a stepped up pipe diameter with rolled bead.). Would make actuator very difficult to mount though so may end up external gate.
Just a thought.
Share this post
Yeah I’ve tried all the fabrication places, dean at rw doesn’t make them anymore, sacha at wepr will only do one with a full pipe kit and intercooler which I don’t need, td don’t do them, id workz no longer do them, hdi don’t sell the pipe kit separately 😩I might have to chance my hand with jperformance and just use PayPal
Share this post
Nightmare trying to find one isn't it mate, I had the same issue. I got lucky a few weeks ago on a second hand one from ebay. If your not in a rush for one just be patient as the do pop up second hand.
Share this post
Shame really, the pipe is quite simple. I guess that the demand isn't enough to make one.
Could also try contacting some sellers on eBay that are breaking glanza's. They may have one.
Edited by Claymore
Share this post
Pm'd
Share this post
Thanks man, but they won’t split the hot pipe unfortunately and I don’t need the rest of the setup ! The hunt continues
Share this post
Use your oem top mount intercooler hotpipe, cut and weld it to the way you want it to be. Job done
Share this post
On 6/9/2020 at 12:47 PM, JamesD89 said:
I have one from a ebay kit I bought years ago if it's any use to you. It's quite short though.
James
Any pics of it mate
Share this post
One in the for sale section dude.
Share this post
